Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 05-01-2004, 04:05 PM   #1
Silverfly
Silverfly's Avatar
Profile:
Question Bowen water heater problem, anyone know what to look at?
Hi there, I have a Bowen water heater (not the original likely about 10 years newer) in my 62 overlander. The pilot lights and stays lit, the burner comes on and stays on for 4-6 minutes then the whole thing shuts off -pilot and burner. The water heater never gets to temp. The heater is full of water, Anyone know what to look at??
Silverfly is offline   Reply With Quote
Old 05-01-2004, 04:28 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
It may just need a good cleaning..
Sounds like what ours did...after taking it out & cleaning all the soot & dead bug parts, it worked fine. If that doesn't do the trick it's probably the thermocoupler.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 05-01-2004, 09:26 PM   #3
Silverfly
Silverfly's Avatar
Profile:
Wink
I'll give it a shot.
Old 05-01-2004, 11:10 PM   #4
Creampuff
Creampuff
Creampuff's Avatar
Profile:  1957 22' Flying Cloud
Malibu Lake , California
Images: 60
The thermostat may be defective. Try dialing the thermostat way up to see if it stays on longer. Mine is a red dial on the control. The ' puffing- out ' problem is probably due to a weak pilot - a separate problem from the first.
If that doesn't work you probably need a new control.
Murray
AIR #189
"If aluminum isn't magnetic- why am I so attracted to to it?"
Creampuff is offline   Reply With Quote
Old 05-04-2004, 10:56 AM   #5
Silverfly
Silverfly's Avatar
Profile:
Smile All fixed!!
Thanks everyone, I removed the burner with thermocouple and pilot assembly. Cleaned and re-installed it . It works like a charm now.
Argosy water fill problem mcneon Argosy Motorhomes 1 10-09-2003 05:30 AM
Bowen W/H burner retrofit Jabba Water Heaters, Filters & Pumps 2 11-26-2002 05:27 AM
Inverter problem Don McKelvay Electrical - Systems, Generators, Batteries & Solar 2 11-03-2002 05:40 AM
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 18 08-18-2002 09:24 AM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
