Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 07-02-2002, 03:09 PM   #1
Profile:
Unhappy Bowen Water Heater
I just got the bad news from the propane shop. ALl of my appliances are now working with the exception of the Bowen Water Heater. The tech says that the controls are shot, and that it will be several hundred dollars to convert it to the newer controls as the older ones are no longer available. Only then, he says, will he be able to determine if the tank itself is working.
Question - Does the predessessor of Bowen still have controls available? Does anyone have experience in repairing one of these tanks they think would be valuable to me? Does anyone know where I could find a working tank?
Thank you in advance
Larry
61BambiCanada is offline   Reply With Quote
Old 07-02-2002, 04:32 PM   #2
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
Re: Bowen Water Heater
Larry
First the tank has a fire tube in it surrounded by water. He can check the tank condition and should check the tank by hydrostatic testing using water before replacing controls. Should be pressurized to 150 %(Verify This Number It May Have Changed) of it's rated capacity. You do not need controls to do this. Ask him about this and if you get a blank stare run don’t walk away he has no clue. Do a search for pressure vessels and hydrostatic testing. ASME
I did mine myself for about $150.00. New control and new pilot and thermocouple. The RV dealer said it couldn't be done. At one time in my life I ran a plumbing shop and changed many a heater control. Be sure the control you use is rated for propane. If you tack on labor you would be better off with a new unit. I did my own labor and really wanted to save the style of the cover to stay with the look and feel of the unit.
Bowen was no help. Get hold of a good plumber not a RV mech. A Hot water heate is a hot water heater the fuel is the difference.
Thanks Jim, N5TJZ
2005 25' Safari ,AIR# 174,WBCCI 5131
S/V Wandering Spirit
http://airstreamlife.ning.com/profile*/JimClark
Check the weather at my home
http://www.wunderground.com/weatherstation/WXDailyHistory.asp?ID=KLANEWOR12
Picture Gallery
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Old 08-14-2004, 07:00 PM   #3
Larry71's Avatar
Profile:  1971 23' Safari
Allentown , New Jersey
Larry
Hi Larry,
I was searching for info on the propane control for my Bowen water heater in a 71 Safari. The only thing I found was a thread from you in 2002 looking into getting repair parts for this heater. I see that you never got any response. I wonder if you ever found out anything and if you did could you share it with me.
Larry
Larry71 is offline   Reply With Quote
Pingbacks are On
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
Bowen water heater Jerry Sulkin Water Heaters, Filters & Pumps 8 08-23-2002 08:26 AM
SEO by vBSEO 3.1.0
