Old 06-24-2002, 08:41 AM   #1
Bowen water heater
I decided to test my hot water heater yesterday for the first time. I have been restoring my 71 Safari for the last year. The tank has been full and under pressure many times and I have fired the burner to make sure it worked but never long enough to completely heat the water. After burning for about five minutes I noticed water trickling out of the main burner tube. I shut it down right away. Is this normal condensation or do I have a major problem?
Jerry Sulkin is offline   Reply With Quote
Old 06-27-2002, 04:32 AM   #2
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Hmmm.....
Those burner tubes are pretty thick, and I believe they are one piece units. I would think if anything was going to go it would be the tank itself. My old tank rotted out on the bottom. I would fire it up again, and let it run until the t-stat shuts down the burner. If the leak gets bigger as the unit heats up, you may have a problem, but I suspect it is condensation.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 08-22-2002, 04:28 PM   #3
Water heater
Hello Jerry,
I am trying to to get my water heater to work. The knob that says on, off and pilot won't move. It is set on "on" now. Any ideas on how to get it to move. I have put a lot of liquid wrench on it, but it still won't budge. Hate to force it. Any suggestions would be appreciated.
Dan Brawner
Dbraw is offline   Reply With Quote
Old 08-22-2002, 04:49 PM   #4
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Re: Water heater
Originally posted by Dan Brawner
Hello Jerry,
Dan Brawner
It's time to replace the regulator. If you have to go do all that to get it turn I wouldn't trust it.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 08-22-2002, 07:19 PM   #5
sovereign's Avatar
mill springs , North Carolina
on some water heaters you have too push the red button to get the knob too turn. but maybe yours is froze up
sovereign is offline   Reply With Quote
Old 08-23-2002, 05:18 AM   #6
water heater
If I have to replace the regulator, where is a good source for them?
Old 08-23-2002, 08:10 AM   #7
Hi Dan,
Can't help you with that one. I had a small leak in my old Bowen after the water got hot. I decided to replace the Bowen with a new 6 gal. Atwood. Glad that I did. If you're looking for a replacement parts try Marks RV web site.
Jerry
Old 08-23-2002, 08:19 AM   #8
Jim Clark's Avatar
Re: water heater
Dan, I purchased mine from a local RV dealer. The inlet and outlet were not the same as the orginal. I had to use a bushing on one or both. Be sure it is rated for Propane.The dealer had a box full, the sales person said that were told not sell them unless they were exact macth. Not much chance of that after 34 years. I convinced her I know what I was doing. Cost was $70.00 or $80.00. Home Depot or Lowes had none rated for Propane.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 08-23-2002, 08:26 AM   #9
Red face Hello - reg water heater, toilet foot and good morning!
Good Morning! We are up early! Glad you all are on the water heater subject
I have just been looking what to put in? Jerry you did a 6 gal Atwood?
I have just finished my clean out of my original aluminum water tank and
now am looking to hook up my entire water source.
I need the water heater, a new toilet foot and seat seal and do any of you know
how hard it is to connect the battery source along with the elctrical source?
My AS is a camper special and I am trying to have it upgraded for both>
ANy suggestions would be helpful. I am truly not sure of what type of battery to get either?
60stradewind is offline   Reply With Quote
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
Bowen Water Heater 61BambiCanada Water Heaters, Filters & Pumps 2 08-14-2004 07:00 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
