Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 08-29-2006, 09:17 PM   #1
76'Sovereign
76'Sovereign's Avatar
Profile:  1976 31' Sovereign
Minneapolis , Minnesota
Bowen water heater
Hey all,
I'm new to this. I just bought a 76 Sovereign 31 ft. trailer and love it!! Although it needs alot of work to it. I am trying to fix the water heater, but the gas valve/thermostat is not coming out of the tank. Are the treads on the old units reverse? or are they standard?
Tim
76'Sovereign is offline   Reply With Quote
Old 08-29-2006, 09:26 PM   #2
Janet
Janet's Avatar
Profile:  Eastern , Washington
Images: 63
standard.
Welcome to the forums.
77 Argosy Minuet, 6 metre
77 Argosy 24, Rear door
AIR 3181, WBCCI/VAC # 5575
Wally for President
Janet is offline   Reply With Quote
Old 08-29-2006, 09:38 PM   #3
scottanlily
Profile:  1960 24' Tradewind
santa barbara , California
Hello 76 sovereign,
that bowen control unit probably is corroded into the threads in the tank.
The controller unscrews counterclockwise as stated by Janet.It may take a big wrench to get it off .If you do ,try to get a look inside,ours on our 60
trdwnd was full of corrosion .I replaced it with a suburban ten gallon.
Many like the atwoods also .
Scott of scottanlily
scottanlily is offline   Reply With Quote
Old 08-30-2006, 06:29 PM   #4
76'Sovereign
Thumbs up It's out
Thanks for the heads up! althought I did have to get my torch out, I did get it out.
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
Bowen Water Heater 61BambiCanada Water Heaters, Filters & Pumps 2 08-14-2004 07:00 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Bowen water heater Jerry Sulkin Water Heaters, Filters & Pumps 8 08-23-2002 08:26 AM
