Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 11-25-2002, 04:14 PM   #1
Jabba
Jabba's Avatar
Profile:
Bowen W/H burner retrofit
Hi All,
First a Happy Thanksgiving to all! Has anyone heard of retrofitting a burner onto a '64 Bowen H/W heater? The trailer I'm getting has a rusted burner and it was suggested to try and retrofit a burner as the heater works, just too much flame. Any suggestions or is it time to replace the whole unit? Thanks in advance!
Jason & Veronica Jablonski
1955 Commodore Vanderbilt/Liner 30'
2008 Chevy Silverado Ext. Z71 w3.73
Jabba is offline   Reply With Quote
Old 11-25-2002, 04:33 PM   #2
overlander64
overlander64's Avatar
Profile:  1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 106
Greetings Jason!
I am not certain whether you will locate a burner suitable for retrofitting, but I don't know whether it would prove out in the long-run. The burner gave out on my Bowen water heater in the '64 Overlander in 1998 - - at that time my dealer was able to find the part, but it was about 1/2 the price of a new tank and there was evidence of corrosion around the tank pointing toward the possibility of pinhole leaks - - long story short, replaced the water heater with a new atwood and am quite pleased.
The only down-side to replacing the water heater is that the new unit will be smaller requiring some patch panels be installed, and you will need to make a decision whether to maintain the '64 esthetic and modify the original water heater shroud or go with the new one that comes with the water heater. Since my original furnace shroud had already been damaged and removed, I chose to go with the new water heater and its door - - I am still trying to get around to painting it aluminum so it doesn't contrast so much with the side of the trailer - - one of the advantages of my Minuet - - its new water heater doesn't shout that it is new.
The following is a photo of the completed installation before the exterior was polished and plasticoated:
There is another photo in my album that shows the front half of the door after restoration, but none that really show the installation well after restoration.
Kevin
Kevin D. Allen
AIR #827
Old 11-26-2002, 06:27 AM   #3
smily
"Still Working"
smily's Avatar
Profile:  North Charleston , South Carolina
Burner?
When you say Burner, what part are you talking about?
The whole unit or just the venturi tube?
I replaced my tube with a new one made of stainless steel because my original had "pinholes" all in the bend. This was allowing to much air to be drawn to the flame and my flame was very yellow and erratic.
I had all components including the "target", (the shield that is on the end of the Venturi tube) and the "collar" that provides air adjustment.
I had the tube bent a little more than 90 degrees, like the original. I tapped a hole in the tube to mount both the "target" and the "collar"
The control box is cast metal so it should not have rusted.
Do you still have the bracket that holds the Thermocouple?
This is an easy fix if you have all of the components.
Mine works great!
Smily
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
smily is offline   Reply With Quote
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 04:51 PM
Need Burner Cover for '73 31' Int'l Tripp Parts Archive 1 06-27-2003 01:01 PM
HELP ! Need burner pilot 74SovereignInt. Furnaces, Heaters, Fireplaces & Air Conditioning 5 12-08-2002 08:41 AM
Bowen water heater Jerry Sulkin Water Heaters, Filters & Pumps 8 08-23-2002 09:26 AM
