Old 06-09-2018, 08:59 AM   #1
1966 22' Safari
Cedar Rapids , Iowa
Bowen Replacement
Hello all,
I have a '66 Safari with the big old Bowen water heater/tank. I've seen where others have stated the Atwood is supposed to be a direct, easy replacement but my front frame opening is 22.5" wide x 17.5" tall and atwood specs are 16" wide x 12" tall. So, when replacing water heater, is there another replacement that I'm not seeing for these old Bowens or is everybody having to re-work the metal around closing up the opening? Thanks all for any and all input!
mysilverbullet is offline   Reply With Quote
Old 06-09-2018, 09:31 AM   #2
Retired.
. , At Large
You will need to plate over the extra open area when using an Atwood replacement.
Also, be prepared for some difficulty removing the old one, they have a mount in the floor that makes it difficult to remove.
Old 06-09-2018, 10:05 AM   #3
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Are you sure the Bowen is not a 10 gallon unit?
Old 06-09-2018, 12:37 PM   #4
1966 22' Safari
Cedar Rapids , Iowa
Actually, just looked a bit closer. While the "framed" area is much larger, the actual opening is more like 18" w x 11.5 high so maybe a new one will fit without too much aggravation? Thanks all!
Old 06-10-2018, 10:49 AM   #5
1966 22' Safari
Cedar Rapids , Iowa
Overlander 63, where is this bolted to floor? I've searched all around tank and inside control area and cannot see anything. Also, tank is higher than opening, does it tilt out to remove. I've removed in/out water lines and LP line and used putty knife to cut through putty but very little movement. Thanks again for your expertise! Greg
Need a Water heater Bowen replacement Russ G Water Heaters, Filters & Pumps 1 04-17-2013 09:12 PM
Bowen Replacement-Cutout Dimensions glang58 Water Heaters, Filters & Pumps 17 04-15-2010 12:00 PM
best (easiest!) '77 Bowen water heater replacement? JohnGalt48 Water Heaters, Filters & Pumps 5 09-28-2009 03:11 PM
Bowen Replacement Pilot Light & Thermocouple The Flintstones Water Heaters, Filters & Pumps 0 11-13-2007 11:25 AM
Replacement for Bowen water heater? 63air Water Heaters, Filters & Pumps 5 07-19-2005 09:17 AM
