Old 06-15-2002, 09:36 PM   #1
melprice's Avatar
Bowen Pressure relief valve
Anyone know where I can get a replacement for the pressure relief valve. Mine is shot.
I went to a regular plumbing supply store and the guy sucked his teeth, ummed a little, aaahed a lot then said, nah, that's a half inch, we're not even allowed to sell them anymore.
I currently have it blanked off just so I can use the cold water system.
Melvin and Sheila
1972 Trade Wind
Cleveland, OH
melprice is offline   Reply With Quote
Old 06-15-2002, 09:40 PM   #2
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Purchased mine at Ace.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 06-15-2002, 09:54 PM   #3
Relief valve
These valves are commonly known as
T&P valves. The true name is temperature and pressure valve. With a couple of fittings a 3/4 inch valve can be connected. There is not any need to connect any piping to discharge of valve.
Home Depot is a good source.....
How did ya determine valve was defective?? If it just leaks, it maybe just filled with hard water. Remove from water heater and place in container of lime away.......Reinstall and test for leaks. The seat in these valves is brass and hard to wear out.....
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 06-15-2002, 10:25 PM   #4
melprice's Avatar
The flat plate that sits right at the end of the valve, I think it's plastic, has blown out of the body.
Melvin and Sheila
1972 Trade Wind
Cleveland, OH
Old 06-16-2002, 06:28 AM   #5
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
Bowen is now owned by Atwood Mobile Products.
The Plumbing Supplier was probably right about selling 1/2" per your local code restrictions, which apply to city building guidelines. Those valves are sized for 30, 40, 50... gallon water tanks.
Any good RV supply store should be able to provide you with a 1/2" bronze temperature and pressure relief replacement valve.
It is Atwood part # 91604. If not here is one link to one.
http://www.rvlifestyles.net/catalog/...X0710140039887
I have Edited my post to add the following:
Remember, this is a safety device. The idea is to keep scalding water at explosive levels from spraying on you and your loved ones should the pressures and temperatures build to a dangerous level. And it does happen. Work arounds are not advised. Use the proper part. Also believe it or not an inactive water heater with water left in it, within only a few weeks, have a Hydrogen build up in the tank. You should always test the valve before lighting the burner or if electric, before plugging in to shore. It only takes a second to test but saves a lifetime of disfigurement.
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 06-16-2002, 06:47 AM   #6
Jim Clark's Avatar
Usea 3/4 Valve and a close nipple and a bell reducer. The issue is vol. if the valve lifts. Do at you own risk.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
Followup to valve stem failure dtbw Wheels, Hubs & Bearings 0 10-29-2003 08:40 AM
City Water Valve Assmbly Question sladew Fresh Water Systems 3 08-11-2003 10:38 PM
