Old 03-21-2008, 02:51 PM   #1
1965 22' Safari
lewisburg , Pennsylvania
Bowen gas line fitting??
Looks to be original bowen heater & unitrol valve for 1965 safari. Having trouble figuring out type of fitting used on the gas line input into the the unitrol valve. I misplaced line during floor repair. It appears a male threaded fiitting would go over 3/8 line then flare the line with the flare sealing directly against bulb built into the unitrol. I cannot find a male threaded fitting that would work. Any insight is appreciated.
PeteL is offline   Reply With Quote
Old 03-21-2008, 05:22 PM   #2
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Welcome to the forum.
Airstream, in my experience, always used commonly available fittings in that era. If the parts you think you need are not available at Home Depot or equivalent, then it sounds like a previous owner has modified the setup.
Please post a picture of the fitting.
Tom
Old 03-21-2008, 05:27 PM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Pete,
First, WELCOME!
You might trying a few differentsizes of flair nuts to see which thread matches the bulb on your Bowen. It's all downhill after you find the correct size flair nut. Oh, BTW............Go for the 'forged' type of flair nut and you'll never break one at the seam....cause there isn't one!!!!.
Old 03-21-2008, 07:05 PM   #4
1965 22' Safari
Many thanks. It was the inverted flare nut that threw me a curve. I guess it is not such a common item these days, unless you are working on brake lines.
new gas line couplings still leak AlbertF LP Gas, Piping, Tanks & Regulators 12 08-28-2007 12:14 PM
Rubber Gas Line Sundance LP Gas, Piping, Tanks & Regulators 4 07-13-2007 05:06 PM
1/4" Compression fitting for air suspension line philippes General Motorhome Topics 4 03-17-2007 08:51 PM
LP gas line question 63air LP Gas, Piping, Tanks & Regulators 5 01-21-2007 09:41 PM
Lost the cooling gas from the line. Astrodokk Refrigerators 1 10-24-2004 09:30 AM
