Old 02-29-2012, 05:10 AM   #1
dryenko's Avatar
dobson , North Carolina
Bowen G6A2 water heater refurbishment
From a 1978 Argosy 27...
Pulled the unit out for suspected leak , found none .
As I understand it, the new units are not alumimum, tankwise, and that doesn't bode well for long life.
With regard to the tank, it seems I was mistaken and there is no inside "coil , just high and low pipe for hot out and cold in, so my issue must have been a small camper pipe system leak, or leaking relief valve.
So, no tank new needed..... the old one is in excellent condition , inside and out.
My plan, while apart, is to incorporate a welded on aluminum bung for a 115 V AC electric element and mount a adjustable control "switch" as used on commercial electric hot water heaters, with a lighted on -off switch somewhere convenient to the bathroom or galley area.
I do wish I could retrofit this Bowen G6A2 unit with a auto ignition gas vlave, but haven't found one yet.....
Know of any available? Sources for same, new or used ??
It seems they are basically all alike, heater brand wise and fitment, regarding there controls, correct?
Thanks for any input !!
BC
dryenko is offline   Reply With Quote
Healthy/Green Fresh water storage tank SteelyDan Classic Motorhomes 23 03-27-2012 08:55 PM
New low tech water heater Globie64 Water Heaters, Filters & Pumps 17 03-05-2012 10:23 AM
High Flow Water Pump - yes / no ? MrJ Mechanics Corner - Engines, Transmission & More... 7 02-28-2012 11:07 PM
Tankless water heater tlynn87 1974 - 1979 Sovereign 8 02-28-2012 09:04 AM
1964 Safari Twin water pump wiring Safari Bob Plumbing - Systems & Fixtures 4 02-26-2012 09:35 PM
