Old 07-14-2007, 08:03 PM   #1
Blaine , Minnesota
Bowen burner assembly
I have a 1965 Bowen water heater and the burner assembly (TUBE) has holes rusted in it. Does anyone know where to get replacement parts?
Gamblersz
1965 Overlander
gamblersz is offline   Reply With Quote
Old 07-14-2007, 11:24 PM   #2
C Johnson's Avatar
1965 17' Caravel
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Well I hate to be the bearer of bad news but that particular part is NLA (no longer available). Does the water heater still work ?? If it does I would use it until it drops dead.
Your only other option is to start asking around at small RV places that look like they've been there for a while. Take it or a picture of it with you so they know what it is you are needing. There are still a few floating around out there, you'll just have to ferret them out !
If you are good with welding you could re-fit a newer style tube to your heater.
You could also replace the water heater with new one.
I got very very lucky when I went looking for a burner tube for my Bowen. The first place I went had one mixed in with a pile of other parts. They had bought out another dealer and it was in with the inventory.
Good Luck !
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 07-15-2007, 08:36 AM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Magic goop
The rusted-out pilot light assembly on my Bowen water heater was successfully repaired with ThermoSteel. I think it would repair your damage too.
Tom
Old 07-15-2007, 09:00 AM   #4
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I traveled the same route as you are 2-3 months ago. No burners or even one close to adapt for my '66. So I installed a new Atwood. I'm glad I did because in removing my old Bowen I discovered it had slow leak that rotted the floor under it. The Atwood is fantastic.
Neil and Lynn.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
Bowen Water Heater 61BambiCanada Water Heaters, Filters & Pumps 2 08-14-2004 07:00 PM
Bowen W/H burner retrofit Jabba Water Heaters, Filters & Pumps 2 11-26-2002 05:27 AM
Idler arm support assembly PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 0 09-11-2002 08:53 PM
Bowen water heater Jerry Sulkin Water Heaters, Filters & Pumps 8 08-23-2002 08:26 AM
