Old 12-14-2010, 07:39 PM   #15
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Installed
There was a small issue with clearance when I threaded the new controller into the tank but it worked out OK. ASfter everything was installed and tightened, I fired it up. Works like a champ! There is a small gas leak on the pilot light supply tube. I tried tightening it, but I think the tube is either cut or not flanged properly. I didn't do anything to it. I came out of the box that way.
ID:	117025   Click image for larger version
ID:	117027   Click image for larger version
Lance
Top is offline   Reply With Quote
Old 01-01-2011, 10:35 PM   #16
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Update
Well, it worked for a while but now the tank is leaking water like a sieve. I guess the old girl just gave out. I think I'll get a Precision Temp RV 500.
Lance
Old 01-01-2011, 11:25 PM   #17
x
XXXX , XXXX
Wow Lance I just checked out the PT RV 500. 2009 price $1054.00 USD. That's very pricey compared to an atwood 10 gal pilot model at $339.63 USD. Plus the dimensions are different the PT is 2.5" less wide and 2" higher and 7" less deep. Is it worth $700 plus dollars and all the mods needed to have on demand hot water. The Atwood 10 gal gas w/ electronic ignition and electric element is only $539.99 USD and will fit right in the spot of the old Bowen.
wasagachris is offline   Reply With Quote
Old 01-01-2011, 11:31 PM   #18
x
XXXX , XXXX
Hey Lance check out this ad. a used Bowen for $75.00. You could swap out the tank in yours and keep the new gas valve etc.
Airstream Appliances & Parts - $25 - Airstream Trailer Classifieds - Airstreams Trailers For Sale
Old 01-02-2011, 09:00 AM   #19
Top
Always learning
Top's Avatar
1972 29' Ambassador
Central , Texas
Images: 24
Thanks WC. I don't think I want to spend any more money on a thirty eight year old water heater. If it was a tank from a 2005 I might bite.
I heard about the PT RV 500 on the VAP and I think it would make our family much happier when the five of us have to get clean after a long day of hiking!
Lance
bowen, lit, water heater
Dometic won't stay lit hagnik Refrigerators 1 04-10-2010 06:33 PM
Atwood HW pilot light won't stay lit LI Pets Water Heaters, Filters & Pumps 9 12-30-2007 03:42 PM
Pilot light won't stay lit abridges01 Refrigerators 5 09-24-2006 11:01 PM
Bowen/Atwood LP to Atwood LP/ELEC./DSI? 65 overlander Electrical - Systems, Generators, Batteries & Solar 9 12-05-2005 06:10 PM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 03:37 AM
