Old 10-04-2010, 01:16 PM   #1
Airstringers
BlueBelle's Avatar
2007 19' Bambi
Irving , Texas
Black soot from water heater
When it gets bad, it just gets worse.
Good info in the threads on this.
It's a sign of not enough air/oxygen. Even if your supply tube doesn't look
like it's obstructed, clean it anyway. Once it starts producing soot, it accumulates in the supply tube and builds up both in the tube and in the
air slots on the adjustment.
(there are also a couple of screws that protude into the tube and they also catch soot and other stuff)
Mine was burning yellow(not enough air). I cleaned it good and now have a nice clean blue flame. The air is easy to adjust by sliding the slotted sleeve. Too much air it roars and burns erratically, too little air and flame goes yellow.
Good luck. The advice here worked for me.
Life is short. Play hard.
BlueBelle is offline   Reply With Quote
Old 10-04-2010, 05:21 PM   #2
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
Also, look for spider webs in the burner tube. That has been my most frequent problem here in Texas.
John W. Irwin
WBCCI #9632
Old 10-04-2010, 05:56 PM   #3
FLYNCLD's Avatar
1962 22' Flying Cloud
Bend , Oregon
My brand new heater produces black soot no matter where I adjust it! I give up!
FLYNCLD is offline   Reply With Quote
Old 10-04-2010, 06:11 PM   #4
Hansom-Man's Avatar
2009 23' FB Flying Cloud
The Woodlands , Texas
Check hard for hornets nest and/or mud daubers. We had a wasp nest fairly deep in that was causing black soot on the side of the camper where it vents. Removed nest and soot problem vanished.
Good luck.
Hansom-Man is offline   Reply With Quote
carbon, soot, water heater
Soot from water heater exhaust ole81 Water Heaters, Filters & Pumps 5 01-02-2008 04:12 PM
Soot from Atwood water heater pilot light nickcrowhurst Water Heaters, Filters & Pumps 4 12-10-2007 12:29 PM
Water heater soot bkahler Airstream Motorhome Forums 4 02-24-2007 07:43 AM
black tank/water heater repair questions kdenault Waste Systems, Tanks & Totes 2 07-14-2006 06:44 PM
Water Heater black smoke grantb4 Water Heaters, Filters & Pumps 5 11-07-2005 09:18 PM
