Old 02-16-2015, 07:37 AM   #1
Woodstock , Georgia
Black Smoke
I have a 1987 Excella. I have a black smoke coming from the water heater vent. I turned off hot water heater. I would appreciate any input before I call the repair company.
Justdirt is offline   Reply With Quote
Old 02-16-2015, 08:12 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Most likely some thing or someone has gotten into the burner tube and changed the air ratio. Spiders like to build nests in there. Stink bugs hold family meeting in there.
remove the tube and inspect. Try not to move the adjustment slide when you do this. This assumes the flame was right before the problem and once the tube is clean and put back on things should be fine.
2004 Excursion 4x4
Old 02-16-2015, 08:24 AM   #3
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Propane itself is dirty - and will build up in the exhaust side of the unit. Because I fulltime, I tend to have a bit more problem than some others with this. Your water heater needs a good cleaning - and probably scale removal from the bottom. (I'm lazy and can afford to hire a mobile RV company that visits my home campground frequently. The greasy dirty mess that comes out when the man cleans it convinced me that it's a chore I like leaving to him. Once a year or so does it for me. )
Old 02-16-2015, 08:35 AM   #4
Woodstock , Georgia
My wife and I love our 1987 34' Excella. I appreciate the prompt response from both HowieE and Foiled Again. Thank you for your time and assistance. The unit will now receive a good cleaning.
Old 02-16-2015, 08:44 AM   #5
1998 30' Excella 1000
Livingston , Texas
I had soot coming out once. It turned out that the tube with the air mixing slots was not perfectly aligned with the brass orifice fitting that it slides onto. It was just a fraction of an inch out of alignment. Visually, it would be hard to notice if you did not look carefully at it. Got it lined up. Soot went away.
Siegmann is offline   Reply With Quote
Old 02-16-2015, 10:11 AM   #6
Woodstock , Georgia
Thanks Siegmann for your reply. I will check the alignment.
Smoke, Smoke Everywhere ncbambi 2008 Safari SE 14 07-25-2010 06:28 PM
Smoke detector Ed L General Appliance Topics 4 05-14-2007 01:58 PM
Furnace sets off smoke alarm silverback 2002 - 2005 International 37 11-12-2006 08:24 PM
Water Heater black smoke grantb4 Water Heaters, Filters & Pumps 5 11-07-2005 09:18 PM
Smoke Detector ViewRVs Airstream Motorhome Forums 7 09-02-2002 07:57 PM
