Old 08-11-2014, 08:13 PM   #1
1968 26' Overlander
Wolfforth , Texas
Best water pump?
We are ready to buy a new water pump for our overlander. It has been gutted and we are redoing all electricity so it can have larger amp. What is the best quietest pump?
lakoria is offline   Reply With Quote
Old 08-11-2014, 08:58 PM   #2
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
Not sure what the "best" is, but mine is a Water King Sure Flow. It's been going for at least 15 years and is pretty quiet. I know Little Giant also makes a nice one.
DryFly is offline   Reply With Quote
Old 08-11-2014, 09:51 PM   #3
1974 Argosy 20
Kooskia , Idaho
Shurflow and Flo Jet both make good pumps.
Old 08-11-2014, 10:17 PM   #4
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
My "regular" Shurflow pump was making some funny noises, so I replaced it with an "upgraded" Shurflow "revolution" pump. The pump noise is now normal, but also quieter. I will let you know in 5 years how reliable it is. I do a lot of boondocking, so it gets used a lot. I got the "revolution" pump from PPL for under $70. Easy peasy, same mounting holes as the old pump. The specs are 3 gpm @ 7.5 amps.
Dan
Pump doesn't turn off and it doesn't pump water either. I don't know what to do! Melimelo Fresh Water Systems 10 05-25-2018 01:39 PM
Best position for water pump and lines bwaysteve Water Heaters, Filters & Pumps 1 01-19-2010 11:42 AM
air pump vs water pump kamo Water Heaters, Filters & Pumps 22 02-27-2008 02:01 PM
68 water pump-should the pump cycle? Boondocker Water Heaters, Filters & Pumps 8 08-06-2006 10:11 AM
water pump replacement - what is best? nola Water Heaters, Filters & Pumps 5 07-23-2006 03:19 PM
