Old 09-06-2007, 10:23 AM   #57
lewster's Avatar
Naples, FL , Hood River, OR
Originally Posted by 62overlander
I want to step back a few paces... the rv500, does that run on propane and 12 volt or propane and 110volt, or is it a small independent battery? Can it be used for boondocking is what I am getting at.
62'O,
The basic operation of the RV-500 goes like this: It is connected to your LP system and the trailer's 12VDC battery system. It is in a dormant state with no demand for either 12VDC or LP until you open a hot water faucet.
The flow of the water is sensed by a special valve within the RV-500 and turns the system on by opening the gas valve and providing the 12VDC to it's control board that creates the signal to initiate the direct spark ignition and lite up the burner.
The water then flows thru the copper tubing surrounding a copper heat exchanger and gets heated before it exits into the hot water piping and then on to your outlet.
When you turn off the hot water flow at the faucet, the valve then turns off the 12VDC, closing the gas valve and shutting down the system, returning it to it's dormant state, waiting to be fired up again when you need it.
It's great for boondocking as you don't use any energy or fuel until you have a demand for hot water, thus conserving both your LP and 12VDC reserves.
Old 09-06-2007, 11:28 AM   #58
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Thanks Lew
I found this very helpful.
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 09-06-2007, 01:17 PM   #59
Baltimore , Maryland
I too want to thank you... I had it in my head that the system required 110-volt to function. Now I,m clear.
Next question is how do I get percision temp to become a contributor to my restoration project? Ambassador Tim..., any suggestions?
Old 10-09-2007, 09:49 PM   #60
cameront120's Avatar
1972 25' Tradewind
Thanks for all the info Lew. I'm seriously considering getting one of these for my Tradewind. With the Canadian dollar doing so well right now, it is looking even more attractive.
My only question would be how complicated is the installation?
North Vancouver, BC
Old 10-10-2007, 07:13 AM   #61
lewster's Avatar
Installation is pretty straight forward. When I put one into my '06 CCD, the biggest challenge and the one that took the most time was enlarging the opening, as Atwoods are about 1-3/4" shorter than the Suburban that it is a direct replacement for.
Trimming back the inner and outer skins is not difficult, just requiring some precise measuring. The actual connections are a snap!
Let me know if you need one. Forum Courtesy Discounts apply.
Old 10-10-2007, 08:01 AM   #62
1972 25' Tradewind
I'll definitely contact you when I'm ready to buy. What do you use for triming the skin? Do you use a reciprocal saw with metal blade or just a pair of aircraft shears?
North Vancouver, BC
Old 10-10-2007, 06:49 PM   #63
lewster's Avatar
Actually, no saw at all........just shears and a nifty little gizmo that is a mini anvil cutter that does not distort the metal......no matter how thin. I'll put up a shot of it when I hit the shop in FL, as the little bugger is currently buried in my van with about 800 lbs. of stuff around it, including the motorcycle.
Old 10-10-2007, 07:58 PM   #64
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Oh please, Lewey, do post a picture. A tool I don't have yet? Geez....
Uwe
www.area63productions.com
Old 10-10-2007, 09:31 PM   #65
lewster's Avatar
Patience, just as soon as I get back! You definitely need this one!
Old 10-10-2007, 09:37 PM   #66
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
could it be "The original ADEL Nibbling Tool" ?? I use one for precise work, good tool and not that much money. Google it, For long cuts there are any number of pneumatic nibblers, but the Adel works anywhere!
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 10-10-2007, 09:43 PM   #67
lewster's Avatar
OK Gang,
For all of you impatient souls out there who just can't wait to buy a new tool, here is the nibbler that I use. There is a more expensive model, but the jaws are the same, just fancier handles. Eastwood Company: Auto Tools, Body Repair, Classic Car Restoration, House of Kolor Paint, Powder Coating
Home > Tools & Equipment > Shop Tools > Metal Working Tools
Mini Nibbler
Unique blade and handle design requires less cutting effort than conventional snips. The metal is held firmly by the die while the movable center blade cuts. Starts from a hole as small as 1/4". Jaws are made from heat-treated tool steel and are replaceable in seconds. Cuts up to 16 gauge aluminum, brass, and copper or up to 18 gauge mild steel. Made in France.
One year hassle free warranty.
Item#ProductQtyPrice28012Mini Nibbler
$29.99
28012 AMini Nibbler Replacement Blades
$19.99
28012 SMini Nibbler Replacement Spring
$2.49
Old 10-10-2007, 09:47 PM   #68
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
Images: 35
ohh- thats nice Lew!! I really like the fact that you can start from a 1/4" hole. Gonna have to get me one- thanks!
www.popasmoke.com
YETI ( 65 Quart )
Old 10-10-2007, 10:06 PM   #69
1972 25' Tradewind
I want! That just became my new favorite tool that I don't own yet!
North Vancouver, BC
Old 10-10-2007, 10:19 PM   #70
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
I wanted to get the ondemand on my new unit but as said the opening need to be enlarge...
I keep the tool reference for later.
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
Water Heater shell frame BobbyW Water Heaters, Filters & Pumps 0 04-29-2002 10:21 AM
Water heater work tool FrankR Water Heaters, Filters & Pumps 1 04-09-2002 10:57 AM
