Old 06-16-2011, 04:52 PM   #1
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
Bad Check Valve in Pump???
Searched but didn't find anything similar so throwing this out there. Put in some new Pex plumbing and had the following situation on the initial pressure check.
Hooked up to city water for the test, the lines filled and had pressure but the water tank was filling at the same time. The pump was hooked up as normally but at present I have no power in the trailer so can't turn it on at this point. Drained the lines, disconnected the pump line that pulls water from the tank and capped off that side of the pump. Tried again and the lines pressurized as normal with no more flow to tank. Nothing new added in this area, just upgraded original drain valves for hot, cold lines and water tank to ball valves. All this follows a complete subfloor replacement so the pump has been stored for awhile.
I pulled the front off the pump and that all looks good. No trash, has a filter on the side, it's clear. Found several parts breakdowns of the pump online but none of them show where the check valve is located. All say " check valve not shown". It's a Shurflo Model # 2088-422-444.
Can someone point me to the location of the check valve in this pump?
TB
tinbender is offline   Reply With Quote
Old 06-16-2011, 06:32 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Add a valve to be safe
I've never had a lot of faith in the internal check valve in the pump. When I installed PEX tubing throughout I installed a valve in the line from the pump. It is near the city water valve. When I go on city water I simply open the city water valve and close the house water valve.
Old 06-16-2011, 07:21 PM   #3
1985 31' Excella
Fresno , Texas
I just had a similar problem. I had a hard time finding the check valve. It ended up being part of the pressure regulator assembly. I was able to take it apart, clean it and get it to work.
Wsmith is offline   Reply With Quote
Old 06-16-2011, 07:56 PM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
I like that. Good idea! Thanks!
Flojet or Shurflo Fresh Water Pump? SilverCottage Water Heaters, Filters & Pumps 8 07-24-2011 03:25 PM
MH check up. To-do-list Octane General Motorhome Topics 9 04-14-2011 03:36 AM
Check Valve Replacement 73 Tradewind constructor Fresh Water Systems 1 03-20-2011 02:02 PM
Water pump leaking between head and motor Ezmoneybcs Water Heaters, Filters & Pumps 4 03-20-2011 07:32 AM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 08:20 AM
