Old 07-30-2010, 12:31 PM   #1
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Atwood won't light
I have finally connected the new Atwood water heater, but it won't light. I have the one with electronic ignition. The ignitor sparks but the burner won't light. What do I check. The gas was turned on and the stove, which is right next door works.
Bill
Just my personal opinion
Old 07-30-2010, 01:56 PM   #2
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Air lock?
Bill let the air bleed out of the gas line before you try to light it. If you are not sure it is getting gas to the burner use bubbles not flame to test!!!! Good Luck, Happy Trails, Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 07-30-2010, 02:55 PM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Ed,
Tried that, loosened the gas line at the WH until I smelled propane, re-tightened. Spark but no whoosh.
Bill
Old 07-30-2010, 02:58 PM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
Check to see if the gas valve is turned on . . . just guessing.
Old 07-30-2010, 03:28 PM   #5
x
XXXX , XXXX
Bill When you try to light do you hear loud clunk of gas valve opening and then click click of ignitor working.
wasagachris is offline   Reply With Quote
Old 07-30-2010, 03:41 PM   #6
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I have gas to the water heater, no valve to turn that I know of.
Bill
Old 07-30-2010, 04:04 PM   #7
x
XXXX , XXXX
Bill ther is no valve to turn on for a DSI ( direct spark ignition) water heater. The sequence is as follows Turn on switch in trailer. 3 to 5 seconds later a lound clunk should be heard. That will be the gas valve opening. A series of clicks will follow, this is the ignitor trying to light the gas. I repeat do you hear this clunk and can you smell propane while it is trying to light. Do you have a multimeter to test for voltage.
Old 07-30-2010, 04:18 PM   #8
x
XXXX , XXXX
Bill here is a wiring schematic for Atwood water heaters. If you have a multimeter check for voltage at the gas valve during ignition cycle. Do not use a test light because damage to circuit board could occur. Let me know what is happening and I will try to help.
Name:	Water Heater Schematic.jpg
Atwood G10-2 pilot light loechli Water Heaters, Filters & Pumps 0 06-18-2010 07:10 PM
Atwood Heater - Red light stays on! Moonstruck Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-06-2009 03:29 PM
Atwood water heater -- light on, no gas or spark ChromeNomad Water Heaters, Filters & Pumps 4 02-27-2009 09:51 AM
Bathroom Atwood panel w/center red light RLS Water Heaters, Filters & Pumps 5 10-01-2008 01:34 PM
Atwood HW pilot light won't stay lit LI Pets Water Heaters, Filters & Pumps 9 12-30-2007 03:42 PM
