Old 05-04-2015, 03:00 PM   #1
BHBadger's Avatar
2014 25' FB Flying Cloud
Rapid City , South Dakota
Atwood Water Heater Lighting Gremlin
After the first "shake-down" campout of the year, the Atwood GE-9xt water heater has decided to succumb to a lighting gremlin. It will not ignite on propane mode unless the exterior access door is open. I have adjusted the air/fuel manifold to as much air as possible with no success. Since it looks a little "tacky" to leave the door open while camped, I'm wondering if anyone has other ideas short of cutting an air access hole in the exterior door!
2014 25' FB twin Flying Cloud
BHBadger is offline   Reply With Quote
Old 05-04-2015, 03:13 PM   #2
1974 Argosy 20
Kooskia , Idaho
I had that problem with one of my Atwood heaters and never did find a solution for it, but in the dim recesses of my memory seem to recall that I read one once, and it almost seems like it was from Atwood themselves. You might try contacting them and asking at any rate.
Old 05-04-2015, 04:39 PM   #3
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
The gremlin in my Atwood water heater was a corroded ground screw for the ignitor.
Old 05-05-2015, 12:15 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
also, I removed the probe which hangs in the flame plume and cleaned off the carbon buildup and oxidation... and the grounding screw.... worked over a year... then had to reseat the connector last week to make it work...
Peace and Blessings..
Channing
WBCCI# 30676
cwf is online now   Reply With Quote
Old 05-05-2015, 03:48 PM   #5
BHBadger's Avatar
Problem solved. Atwood technical folks had no idea what was causing the problem, but like me thought it sounded like air flow. I removed plastic cover from small inspection hole on door, but no change. Finally, I reoriented the igniter wire to ensure that it would not make contact with the door when closed. System works fine now. Since the wire is insulated, I doubt that it is grounding out, so I suspect some minor break in the wire. Guess I will order a spare.
Thanks for the advice!
Old 05-05-2015, 03:56 PM   #6
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
There is so little "current Flow" in that circuit that proximity to the metal door and any chafing of the wire could disrupt signal. Replace the part of it acts up again.
Also, if you put some high temp tubing over the line that would help isolat the wire from touching the door. Just keep away from too much heat.
Channing
WBCCI# 30676
Old 05-05-2015, 10:39 PM   #7
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
The igniter wire is not very thick insulation for a high voltage spark. Think spark plug wire thickness size. Repositioning it so it can not jump to ground through the insulation is (was) the answer. Try holding on to it while it is sparking and touch metal on the trailer. Then you will know for sure.
Electrical Gremlin...Help sailorii Electrical - Systems, Generators, Batteries & Solar 6 09-29-2014 12:27 PM
Atwood water tank-lighting problems! glacierrunne Water Heaters, Filters & Pumps 2 09-26-2014 12:30 PM
lighting pilot on Atwood heater funkill Water Heaters, Filters & Pumps 8 09-08-2009 07:42 PM
Electrical Gremlin.. JKWoodrow Classic Motorhomes 3 12-18-2006 06:12 PM
electical gremlin bhsl8 Electrical - Systems, Generators, Batteries & Solar 4 09-10-2002 05:48 AM
