Old 06-25-2004, 04:16 PM   #1
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Atwood water heater drain valve...
I would like to replace the water heater drain plug with a valve so I can drain it easily after each trip.
I went to a couple of home stores and could not find a simple nylon valve that would fit in the space provided.
The area is so cramped because of the lp line that it would have to be a short valve. I was thinking of using a nylon adapter that goes to a barbed fitting to a short hose. Then put some kind of valve on the end of the short extension.
Has anyone come up with a neat idea for this?
-Tim
theVAP - Airstream Podcast
Old 06-25-2004, 08:09 PM   #2
RichardT's Avatar
Home stores are not the place to look.
Go to an auto parts store and look for a radiator drain valve that will work, it will likely be brass, and there is no need for a hose.
RichardT is offline   Reply With Quote
Old 06-25-2004, 08:14 PM   #3
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Hmm...Since the tank is aluminum, would a brass plug cause a deterioration situation? I always thought you had to be careful with dissimilar metals. Hence the plastic drain plug in the aluminum tank.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-25-2004, 08:19 PM   #4
WayWard Wind's Avatar
2004 25' Safari
Water heater drain valve
one of the camping mags I have has an anode rod that fits in the 6 gallon & it has a built in drain valve, in the center of the rod. That's what I'm going to be ordering ,when & if I ever get our "new unit back from the corrections center" at JC. On our last unit I picked up a valve from HD & put that in where the drain plug was located. I then attached a short plastic hose to drain the water out away from the unit. Worked great, but I like that anode rod thing, so will be going that way, with the new unit.
Best,
Home of the Wayward Wind
Bogfrog & Mr. Turbo
If in life you stumble, make it part of the dance
WayWard Wind is offline   Reply With Quote
Old 06-25-2004, 08:19 PM   #5
RichardT's Avatar
Jack
The way it is on mine there is a nylon plug with a threaded hole filling the hole in the heater and that has the brass radiator drain in that so no contact between the metals
Old 06-25-2004, 08:59 PM   #6
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Richard,
I like your idea about the drain. I think I should be able to make that work.
On the other hand, when I installed my atwood I used brass nipples on the water lines because I could not find nylon ones.
I did wrap them with teflon tape pretty good. Perhaps that will save me from the dissimilar metals problem?
-Tim
Atwood water heater uwe Water Heaters, Filters & Pumps 5 10-03-2009 01:58 AM
water drain valve leaking - help! wayner1239 Fresh Water Systems 14 02-01-2004 04:10 PM
water drain valve leaking - help! wayner1239 Waste Systems, Tanks & Totes 0 01-31-2004 10:03 AM
Plastic water drain valve Waterman Plumbing - Systems & Fixtures 5 10-29-2003 10:51 AM
