Old 11-08-2010, 10:07 PM   #1
1988 25' Excella
Trumbull , Connecticut
Atwood water heater drain plug
As you all know the drain plug on the attwood water heater is almost impossible to get because the gas line is right in front of it. What have any of you come up with as a solution to this problem of removing the drain plug. Regards nbm1oqrz
nm1oqrz is offline   Reply With Quote
Old 11-08-2010, 10:11 PM   #2
1973 31' Excella 500
Spring Green , Wisconsin
I've been able to get an open end wrench in there to remove mine on a couple different Attwood water heaters.
Lew TAC #WI-6
Nobody can help everybody, but everybody can help somebody.
driftless is offline   Reply With Quote
Old 11-08-2010, 10:38 PM   #3
1988 25' Excella
Thanks for the reply. I need to modify a socket and see if that will work
Old 11-08-2010, 10:53 PM   #4
_
i use a flex socket
attached to 19.2 v cordless drill/driver with a 1/2 inch bit driver
very easy to remove the plug this way...
RE inserting is done by hand,
then tightened with the drill/driver on low speed.
works fine.
the bit driver adapter could be turned with a T handle hex driver, or...
one could use the flex socket with long thin extension and regular ratchet too.
cheers
2air'
Old 11-09-2010, 06:23 AM   #5
Kevin245's Avatar
We ditched the plug and installed a compact ball valve rated for this application. Draining is no longer an aggravation.
Kevin
ID:	114827   Click image for larger version
Eleanor Roosevelt
Old 11-09-2010, 06:27 AM   #6
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
After a few years of fighting with the plug I removed it, put a brass nipple in the hole, connected a 12" stainless supply line on that and put a cap on the end of the line. This works great although I like the idea of the ball valve as well
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 11-09-2010, 06:38 AM   #7
1961 22' Safari
Fayetteville , North Carolina
Images: 30
I replaced it with a radiator pet cock.
mgann is offline   Reply With Quote
Old 11-09-2010, 07:29 AM   #8
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Kevin
That's a great idea.... on the list for next year.
Old 11-09-2010, 08:14 AM   #9
erock53's Avatar
1978 31' Sovereign
Cincinnati , Ohio
I used to battle with it also, but I use the lug nut wrench from my truck. I have one of thoes wrenches with 4 different sockets on a cross that you use to take lug nuts off. One of them is the same size as the water heater plug. And for me, it fits right up there.
Eric
http://e-rock53.blogspot.com/
TAC#: OH-13
erock53 is offline   Reply With Quote
Old 11-09-2010, 08:20 AM   #10
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Slip lock pliers have worked just fine for me for 10 years.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 11-09-2010, 09:09 AM   #11
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Channel locks.
Gene
Old 11-09-2010, 09:15 AM   #12
aftermath's Avatar
Spokane , Washington
Small crescent wrench works for me. I do like the idea of the ball valve though and will look into one.
aftermath is offline   Reply With Quote
Old 11-09-2010, 10:14 AM   #13
Kevin245's Avatar
I believe it was part number 4112T63 from www.mcmastercarr.com
Eleanor Roosevelt
Old 11-09-2010, 10:17 AM   #14
Safari64's Avatar
1964 22' Safari
Eagle River , Alaska
High pressure PVC pipe fitting with 45 degree angle fitting then 1/2 turn ball valve.
1/2 twist to drain, 1/2 twist to close.
Fits inside cover nicely, drains where I aim it (not on my foot).
Safari64 is offline   Reply With Quote
Where is the fresh water drain plug located? bambid Fresh Water Systems 10 06-24-2010 08:47 PM
Fresh water drain plug sticks skipj Fresh Water Systems 16 11-06-2009 06:43 PM
Tool to remove fresh water drain plug willbrackman Fresh Water Systems 5 06-19-2009 10:44 PM
Bowen B10G water heater drain plug lebolewis Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-20-2008 11:49 AM
Atwood water heater drain valve... Safari Tim Water Heaters, Filters & Pumps 5 06-25-2004 08:59 PM
