Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 02-04-2011, 06:50 PM   #1
richinny's Avatar
2011 34' Classic
Atwood water heater burnt wire
anyone have any comments?
the gas works but the 120v fried this wire. in was in operation for a few weeks before it happened. the trailer is two years old.
the pictures show the back of the heater (no damage)
the inside of the element cover with module (slight melting of the cover)
the melted and burnt wire connection.
i am waiting for a reply comment from atwood.
Name:	back of heater.jpg
ID:	121416   Click image for larger version
Name:	element cover.jpg
Ricky
Old 02-04-2011, 07:42 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Is that a burnt up wire nut? Looks like it was a bad connection from the get go. Cut off the burnt part of the wires. Strip them back, twist them together with pliers, turning the pliers clockwise. Then screw on a new wire nut of the proper size. Turn the wire nut on by hand making sure it is tight. It must tighten completely without spinning on the splice. If it spins go to the next smaller size wire nut. Wrap electrical tape around it whne your done. Clockwise looking at the end of the splice.
Old 02-04-2011, 08:24 PM   #3
2005 19' Safari
GLENDALE , AZ
Personally, I'd recommend using an insulated, crimped butt-splice. It'll make a much more secure mechanical and electrical connection.
Old 02-04-2011, 09:49 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Butt Connectors don't work well on solid wire. There is really no crimping of the conductors when you are dealing with solid wires. Butt connectors do work well on stranded wire.
Old 02-05-2011, 06:33 AM   #5
richinny's Avatar
2011 34' Classic
thanks for the replies.
i think it is stranded wire. (it's a friends trailer) and yes that used to be a crimp wire connector.
when reconnected i'm going to put an ammeter on it to see what the load is. i read that atwood reduced the elements from 1500 watts to 1400 watts on some units.
Ricky
Old 06-21-2011, 07:27 AM   #6
richinny's Avatar
2011 34' Classic
i see i never updated this post so here goes.....
the wire was reconnected and all worked well. i did contact atwood and sent the pictures as requested but atwood never replied.
i did find on the atwood site that atwood has reduced the wattage of replacement heating elements. there was no mention of why.
Ricky
burnt wire, water heater
Furnace and Hot water heater complete Airdaddy Furnaces, Heaters, Fireplaces & Air Conditioning 3 02-02-2011 09:16 PM
Is it a water pump or an electrical problem? Taj MaHaul Water Heaters, Filters & Pumps 7 01-23-2011 07:20 AM
Landscape Wire Brianv512 Electrical - Systems, Generators, Batteries & Solar 13 01-06-2011 10:00 PM
Panel indicator light for water pump and Water heater DJW Water Heaters, Filters & Pumps 3 01-05-2011 07:01 PM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 05:42 PM
