05-27-2017, 12:42 AM
2008 25' Safari FB SE
San Diego
Atwood water heater and anode rod
2008 safari 25fb. Looks like I need to replace the rusty cover, not sure if that's part of the anode rod. Any advice on the specific parts # and description of that part?
05-27-2017, 12:48 AM
1984 29' Sovereign
Savannah
, Missouri
That the drain valve, remove it replace with new. It's dark now take photo in daylight for you
WBCCI 5292 AIR 807
NEU #64
New England Unit
05-27-2017, 05:59 AM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
The hot water heater on "Newer" Airstreams (and I'm not sure if an '08 counts as "newer" in this context) do not have an anode rod. What you are showing is (as previously indicated) the drain valve. It's easily replaced and you should do that soon to avoid having it fuse to the tanks itself.
Bob Martel
WBCCI# 5766
05-27-2017, 06:07 AM
1993 33' Land Yacht
Midland
, Michigan
Atwood water heaters have an aluminum tank, no anode rod. Suburban water heater are steel and have the anode rods.
05-27-2017, 06:45 AM
Biloxi
, Mississippi
I put one of those after market drain valves in mine and it started rusting and leaking within a short time. I pulled it and put the stock plastic threaded plug back in place and no more leaks or rust of course. My 2006 has no anode.
MICHAEL
05-27-2017, 09:21 AM
1984 29' Sovereign
Savannah
, Missouri
WBCCI 5292 AIR 807
NEU #64
New England Unit
05-27-2017, 10:08 AM
Tampa
Originally Posted by 53flyingcloud
I'd be cautious about putting a brass drain plug into a aluminium tank. Electrolysis will weld the parts together.
I have a similar tank with a plastic (nylon?) plug. I got a socket to fit. If I want to drain it, I just remove the plug, no dissimilar metals!
05-27-2017, 11:20 AM
Home of Vortex tuning
2013 27' FB Eddie Bauer
Spearfish
, South Dakota
I've run brass in my Atwood WH for over 10 years, with teflon tape, no issues.
I had to cut the remaining nylon plug from the threads when it broke and twisted off during an annual flush out, that is why I went brass.
"Chip Tank" is in Westwood Ca.
05-27-2017, 11:35 AM
Sag Harbor
, New York
A little Teflon tape on the plastic (or brass) plugs helps prevent breakage down the road.
05-27-2017, 12:54 PM
2000 25' Excella
Northern
The "original" factory plugs are nylon, and they tend to distort or become damaged during removal. I replaced mine with a pvc 1/2" plug. Hot water deteriorates pvc over time, so you wouldn't do your hot water plumbing with it; however, I've never been able to find a 1/2" cpvc plug. Regular pvc plugs are cheap, maintain their shape, readily available, and it takes several years of regular RV use to adversely impact them. If it bothers you, they can be replaced annually, but it's not necessary.
05-29-2017, 08:11 PM
2017 30' International
Lincolnwood
anode rod removal ??
At winterization in january the rv dealer installed an anode rod on my 2017
international tt. Is this a problem and should I remove it in favor of a plastic
plug that was part of original equipment ??
05-29-2017, 08:13 PM
1984 29' Sovereign
Savannah
, Missouri
Wrap the thread with teflon problem solved
WBCCI 5292 AIR 807
NEU #64
New England Unit
05-29-2017, 11:32 PM
1979 23' Safari
Wayland
, New York
Yes, if it's an Atwood, get the anode rod out of there. It will cause more corrosion in the aluminum tanks. Put in a plastic plug.
For the op and others. If you have a hard time getting a wrench in there, there are 2 screws holding the center section of the heat shielding above it, by the green wires and down in the lower left corner. The shield comes out easily and makes removing the plug easier.
05-30-2017, 04:26 AM
San Diego
Thanks Joe Silver. I presume I will also need to release the pressure (with the valve lever on the top right) before removing the drain cover, is that right?
05-30-2017, 04:34 AM
Sag Harbor
, New York
Just open any faucet in the trailer to relieve the pressure. If your drain plug is in such rough shape your pressure relief is probably suspect too. Consider replacing both IMO.
If you can back the small T-handled drain valve out of the plug, you might be able to get a socket on the remaining part, without having to take things apart as Joe suggested. Worth a try anyway. When you install a new plastic drain plug, it is worth the time to get the correct socket and extension. Plus Teflon tape on the threads.
Good luck?
Peter
05-30-2017, 05:07 AM
Sag Harbor
, New York
"Good luck!" -- missed the edit time window.
05-30-2017, 05:16 AM
San Diego
Lol...thought it was intentional, which is ptobably appropriate for this case
