Have you got the original "pancake" style pilot? It looks like 2 parallel disks, just slightly separated. They can corrode and get clogged up between the disks. Mine did the same thing (and was actually a pain to to get to stay lit), so I retrofitted a newer style to mine (hard to describe, but it looks like a notched tube with the tip bent a little at the notch). It didn't require too much modification to get it to fit and has worked well so far. Cheers!
1971 25' Airstream Trailer, 1994 F350 CC DRW 7.3L PSD Life is Good in Bear Valley Springs!
