Old 12-27-2009, 03:10 PM   #1
Okiegent's Avatar
1983 31' Excella
Choctaw , Oklahoma
Images: 14
Atwood Water Heater
1983 Excella rear bath. I have a water heater I drained the other day. I noticed the drain plug had quite a bit of sediment on it. It looked as if though it had a element on it about 3 inches long completely covered in sediment. The drain plug was a simple pipe thread plug nothing fancy. My concern is. Do I need to replace this? Was there ever a sensor or element or has sediment grown on it that much. Kinda hazy I know but this is all I have to go on. Thanks for your input.
Tom C.
Okiegent is offline   Reply With Quote
Old 12-27-2009, 03:16 PM   #2
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Sounds as though you may have pulled your anode rod,it is there to be eaten up,and save the tank,it`s not necessary to change unless it is really eaten up. Dave
easyride is offline   Reply With Quote
Atwood Water Heater wingfoot321 Water Heaters, Filters & Pumps 11 10-05-2010 04:52 AM
Atwood water heater uwe Water Heaters, Filters & Pumps 5 10-03-2009 01:58 AM
atwood water heater minuet7.3 Water Heaters, Filters & Pumps 1 08-15-2008 04:12 AM
Atwood Water Heater SilverGate Water Heaters, Filters & Pumps 2 04-15-2007 06:00 PM
