Old 02-15-2007, 02:00 AM   #1
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
Atwood Water Heater
Attention Modern Atwood Water Heater Users:
(Iíll give the answer before the question this time.)
My 2007 23í Safari SE was made in December 2006 and has Atwood L.P. Gas Heater, Model G6A-8E.
At my Airstream Dealer, the service tech, during his walk-through with us, suggested it would be a good idea to remove the hot water drain plug and replace it with an Anode Rod to prevent corrosion. (We reviewed our videotape of walk-through to confirm what he said).
At least our Atwood Operation and Maintenance Manual was not one of the 20 or so missing manuals from our Delivery Case. On page 2 of this manual it says, "DO NOT MODIFY WATER HEATER IN ANY WAY."
On page 4 it continues, "Atwood's written warranty states - 'failure or damage resulting from any alteration to our water heater is the owner's responsibility'. Any alteration... will void the warranty".
So I called Atwood - Division of Dura Automotive Systems, Service Department this morning: 574-264-2131 about this issue.
They said, "Yes, removing the water heater drain plug and replacing it with an anode rod would void their 2-yr. warranty!"
They said the tank is built to resist corrosion and that I should just follow the Preventative Maintenance instructions in my Atwood Operation and Maintenance (Literature Number MPD 93756) Manual.
So it looks like it is not a good idea to use the anode rod until after your 2-yr warranty is up!
And another good reason to ensure that you have all manuals, operating & care instructions for all components of your trailer. And it would be ideal to make sure you receive them from your dealer when picking your trailer and signing off that you received the manuals!
SilverGate
SilverGate is offline   Reply With Quote
Old 02-15-2007, 05:12 AM   #2
lewster's Avatar
Naples, FL , Hood River, OR
Anode Rods......
are found in every water heater made by SUBURBAN due to different tank construction and alloy. Atwood claims that the alloy mix they use does NOT require the use of an anode.
They WILL NOT HONOR their warranty, and I had a situation last year where the owner installed a 'Hot Rodd' electric heating element into the drain as a heating booster. When the board failed and was to be replaced, the presence of the aux. heater voided the claim.
The company literature claims that an anode is not required. I haven't seen many Atwoods that had tank failure. Just be sure to drain and flush out the tank once a year and you should be fine.
Old 04-15-2007, 07:00 PM   #3
millvalleyca's Avatar
2008 27' International CCD FB
Mill Valley , California
temperature control
Hi SilverGate
Looks like we have the same water heater.
Does your heater have a White Rodgers control or a Robertshaw unitrol?
millvalleyca is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 06:16 PM
Help!! Hot Water Heater Flame is Too High emmy Water Heaters, Filters & Pumps 3 03-02-2006 03:29 PM
hot water heater Mary Water Heaters, Filters & Pumps 2 08-12-2002 10:15 AM
lighting water heater susan martin Water Heaters, Filters & Pumps 2 07-27-2002 11:13 AM
Leak in hot water heater tank Rog0525 Water Heaters, Filters & Pumps 8 06-10-2002 03:10 PM
