Old 03-13-2013, 03:37 PM   #1
steveirving's Avatar
1959 24' Tradewind
Quantico , Virginia
Images: 11
Atwood Water Heater
Hi,
Our '59 has a propane Atwood 6 gallon G6A-7 water heater. On the outside lower portion of the tank I see a drain plug with a square end. I suspect this is for the zinc anode. I pulled it, drained the krud from the bottom of the tank, but found only a rusty end on the plug. There should be a zinc here, yes?
Can anyone offer up a part # or place to get this plug?
Steve
steveirving is offline   Reply With Quote
Old 03-13-2013, 03:52 PM   #2
1988 32' Excella
Robbinsville , New Jersey
No, you should not have a zinc anode in an Atwood water heater.
Old 03-13-2013, 04:01 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Originally Posted by steveirving View Post
Hi,
Steve
If the anode is completely gone, there's no telling how long it's been gone, unless you were the one who changed it last time. If it's been gone for a while, then you really need to flush the water heater, and see if the water comes out rusty. If it does, then you might be looking at a corroded heater core, and buying a new heater instead of an anode.
Parts66 carries anodes. So does Camping World. Price is under $20 per rod.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-13-2013, 04:11 PM   #4
Oh, yeah. Forgot about that. The Atwood G6A7 has an aluminum-clad tank, and no anode.
Camping World sells an anode they say is for Atwoods, but this particular model doesn't need them.
WBCCI #1105
TAC LA-4
Old 03-13-2013, 04:12 PM   #5
1977 Argosy 24
Milltown , Wisconsin
Atwood does not recommend putting an anode in their water heaters. Yes I know camping world sells them for the Atwood. Anodes are used in glass lined steel tanked water heaters. Atwood's have aluminum tanks, so no anode is needed.
edit once again I typed too slow.
ventport is offline   Reply With Quote
Old 03-14-2013, 06:01 AM   #6
1959 24' Tradewind
Quantico , Virginia
Images: 11
Thanks guys
