Old 04-14-2004, 09:20 AM   #1
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Atwood Question
do Atwood water heaters not have an anode rod? Is this because the tank is aluminum? What maintenance besides draining the tank then is needed?
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 04-14-2004, 09:51 AM   #2
Alan, my Atwood aluminum tank corroded out, and the new replacement didn't have an anode. I purchased one from the local RV supply store. It replaces the drain plug. There can be stray electrolytic currents if the sediment in your water contains metallic ores, or there is contact with any steel parts of the trailer. IMHO, an anode is an inexpensive way to lengthen the life of the tank. Beyond that, you need to blow out the sediment which forms at the bottom of the tank, below the level of the drain plug. You can buy a curved tube which fits on the end of a water hose. This is also available at RV stores. You run the water through the hose at full pressure while the tube is inserted through the drain plug hole. Waggle the tube through 360 degrees , and keep it moving for a couple of minutes. With my tank this shifts some nasty grunge. The other task is to keep the burner tube clean. The tube is removed (mark the place on the slider so as to reassemble it identically), and cleaned with a "bottle brush", again a specialist tool from the RV store. I also use a brass wire brush on the thermocouple to remove any carbon deposits. Have fun! Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 04-14-2004, 09:54 AM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Thanks Nick. Last fall I vacuumed out the inside of the tank from the drain hole using my shop vac and a small tube I taped to the hose...guess that might have gotten out the crud? It pulled a lot of water through.
AIR #005
retired!
New Water Heater- Suburban vs Atwood PizzaChop Water Heaters, Filters & Pumps 5 02-26-2004 04:48 AM
New gaskets for Atwood 6 gal water heater j54mark Water Heaters, Filters & Pumps 0 01-03-2004 12:46 PM
Rust Question drober05 Airstream Motorhome Forums 6 10-05-2003 02:09 PM
Atwood 7916-II furnace Silvertwinkie Furnaces, Heaters, Fireplaces & Air Conditioning 0 05-17-2003 11:05 PM
Loaded question: avg miles per set of brake pads John Brakes & Brake Controllers 2 12-12-2002 05:01 AM
