Old 08-28-2008, 10:02 PM   #1
cameront120's Avatar
1972 25' Tradewind
Atwood Overheating
My 6 Gal Atwood gas/electric with electronic ignition appears to be heating the water to an excessive temperature and locking out until it cools down. It just started doing this today. Has anyone had experience with this and know what is necessary to correct it? Thanks in advance!
North Vancouver, BC
Old 08-28-2008, 10:31 PM   #2
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Yep
Had that happen, it over heated to the point the pressure relief valve popped.
Turns out there are two thermostats that either break or the plastic holding them down gets too brittle to hold them in place. The latter happened to me. Easy fix though, you can buy a kit that has both T-stats and new hold down material. Comes on a card from your local RV center. Took me all of 15 minutes to replace them. No further troubles.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 08-29-2008, 07:45 AM   #3
1972 25' Tradewind
Thanks Gary. Looks like I'll pay a visit to my local RV shop!
North Vancouver, BC
Old 08-29-2008, 08:04 AM   #4
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Had the same thing happen with our Suburban. Had an RV tech come out and he pointed out that one needs to drain the tank, flush it out and clean off the heating element once a season. Mine was quite cruddy and built up with calcium deposits partly because of Phoenix's bad water. Have plans to do this again after this weekend's trip. When reinserting the heating element, use teflon tape. Looks to be a simple service.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 08-29-2008, 08:12 AM   #5
1972 25' Tradewind
Thanks Brad, I can do that as well. Mine is only a couple of months old though, so I'm not sure it could be gummed up already. Will check to be certain though. Does anyone know how one accesses the heating element on the Atwood models?
North Vancouver, BC
Overheating Boom Sounds Mechanics Corner - Engines, Transmission & More... 3 07-26-2008 08:14 PM
A/V System is overheating benwilbanks Audio, Video & TV 3 04-27-2008 06:22 PM
Overheating Chaplain Kent Mechanics Corner - Engines, Transmission & More... 14 08-15-2007 08:23 PM
Motorhome Overheating Problems geodude1958 Mechanics Corner - Engines, Transmission & More... 14 08-12-2006 08:22 AM
Bowen/Atwood LP to Atwood LP/ELEC./DSI? 65 overlander Electrical - Systems, Generators, Batteries & Solar 9 12-05-2005 06:10 PM
