Old 03-31-2011, 01:27 PM   #1
MissPearl's Avatar
1989 29' Excella
Pauline , South Carolina
Atwood overheat
I've got an '89 Excella. We accidentally fired up the water heater with no water in it!!! It melted the plastic fittings out of the back before shutting off! I pulled the heater; replaced fittings and reinstalled. It fired up just fine, but it won't shut off. Gas stays on all of the time too!
**Is this an ECO - thermostat issue?
**Is this a circuit board issue?
**Could I have hooked the wires up wrong? brown to brown; yellow to blue; white to green??
MissPearl is offline   Reply With Quote
Anyone run out of hot water using a 6 gallon? robwok Water Heaters, Filters & Pumps 44 09-20-2017 03:27 PM
Atwood water heater burnt wire richinny Water Heaters, Filters & Pumps 5 06-21-2011 08:27 AM
Fantastic Fan jomondnv Roof Vents, Skylights & Fans 39 04-18-2011 12:42 PM
Batteries won't run Furnace 6PackCharlie Furnaces, Heaters, Fireplaces & Air Conditioning 12 01-31-2011 11:39 PM
atwood water being fitted to a 1960 Overlander Lothlorian Water Heaters, Filters & Pumps 10 01-01-2011 06:42 PM
