Old 10-24-2010, 11:27 AM   #1
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
Atwood or Suburban pros cons
I am trying to decide on a new water heater.I am to the shell so it could be anything.It's just me,28ft. Ambie and maybe a guest occasionally.
6 or 10 gal. I know I want gas/elec with direct spark pilot.Pros cons of the 2 ?
bwaysteve is offline   Reply With Quote
Old 10-24-2010, 02:15 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
I bought a 6 gallon Atwood with electronic ignition and 110 volt heating element. The reason I picked Atwood is it fit my hole. The reason I picked 6 gallon is it gives me an additional three inches at the area of the toilet. The reason I picked electric ignition is I don't like lighting pilot lights. The reason I picked 110 volt electric as an additional heat source is I couldn't imagine being sorry I did that.
Gary
Old 10-24-2010, 05:19 PM   #3
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
says all
Gary
That about says it all.Does it recycle hot pretty quickly on 110?
Old 10-24-2010, 05:28 PM   #4
x
XXXX , XXXX
Is that your water heater just in front of the wheels cubside. I`m pretty sure the new Atwood will be smaller than the opening for that one. The Suburban is even smaller. Can you post close up pic of your heater or dimensions of opening.
wasagachris is offline   Reply With Quote
Old 10-24-2010, 06:01 PM   #5
Splitrock's Avatar
My water heater as well as the rest of the plumbing is seasoning until I have a motivation spasm or until spring overtakes my good intentions.
Old 10-24-2010, 07:16 PM   #6
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
room
Don't have a closeup of the hole,but it is plenty big.Pulled a 10 gal. Bowen out.Have 30 gal. fresh tank so just looking at options.
Old 10-24-2010, 08:29 PM   #7
x
XXXX , XXXX
Atwood lists their dimensions for a 10 gal heater at 15.75 inches high by 16.25 inches wide and 21.75 inches deep.
Old 10-24-2010, 09:38 PM   #8
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
I am fabricating with a piano hinge a cover for the unit.I will use the old 60's heat vent so I will probably need to make a patch to make my hole smaller and redesign the stove vent for the old unit ,or swing open when HW is on.
Gaucho vs Dinette - pros and cons bertro General Interior Topics 24 08-22-2010 07:47 PM
Looking to find a MH but which one? Pros & cons? crashxx General Motorhome Topics 24 06-13-2009 03:38 PM
'66 Safari or '66 Overlander Pros and Cons yankeemomto3 Member Introductions 10 02-17-2009 08:21 AM
WDCU Pros/Cons rseagle WBCCI Forum 14 09-21-2006 05:45 PM
Club Memberships ...pros and cons? Leesure Our Community 12 06-01-2006 10:12 PM
