Old 02-05-2018, 12:10 PM   #1
Anywhere , Alabama
Atwood Mixing Valve
2018 27' Flying Cloud. Anyone know if the mixing valve on the Atwood 6 gallon hot water heater is user adjustable?
Matt & Pam Padgett
Anywhere, USA
2016 Ford F-350 Dually
lukeysh714 is offline   Reply With Quote
Old 03-27-2018, 01:17 AM   #2
Laguna Beach , California
I’m taking mine off tomorrow and will let you know. According to my web searching it is but they plug the adjustment screw with glue at the black plastic cap. Will confirm when I get it removed.
Calm is offline   Reply With Quote
Old 03-27-2018, 02:21 PM   #3
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
I just replaced this valve on my 2015 Classic -- symptom, water not hot enough, reduced flow. The part was $169.
After removing the old mixing valve and installing the new part it worked “as new.”
Then, I decided to take the old one apart. You CAN adjust the temperature: Remove black cap after prying out the center plastic button. Then PULL the larger black cap completely OFF the valve. If you look carefully, you’ll see a pen marking on the adjustment part and the part that does not move. Atwood did that when they set your temp. You can rotate the outer brass part left and right if you want to change the temperature hotter or colder.
The failure of my original valve was due to calcium formation. I removed all three of the pipe connectors, dumped the entire assembly in a mild solution of muriatic acid. It is now like new and will be ready to serve as a spare when the $169 valve gets crudded up.
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 03-15-2019, 12:13 PM   #4
Kensington , Maryland
My Atwood mixing valve failed. Is there any reason not to remove it entirely and replace it with a cutoff valve?
2017 25' FC FB "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 03-18-2019, 01:04 PM   #5
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
Good question!
sheriff1 is offline   Reply With Quote
Old 03-18-2019, 01:33 PM   #6
2007 22' International CCD
The problem is that the water heater thermostat is calibrated to make scalding hot water, then the mix valve cuts that down to a more reasonable temperature for use. This gives you more hot water than the capacity of the tank alone, but adds to the complexity and maintenance issues, as you see.
Not that you canít do this, but it then increases the chance of severe burns if you are not super careful. Personally I donít like the risk. My Atwood didnít have a mix valve, and I replaced it with a PrecisionTemp tankless water heater.
Old 03-19-2019, 05:33 AM   #7
Thanks RM I hear yah. The deed is done. We will be careful!
Old 03-19-2019, 01:57 PM   #8
Senior Member
sheriff1's Avatar
Sparks , Nevada
Let us know your option after you have a chance to use it.
Thanks!
Old 03-26-2019, 04:06 PM   #9
Thanks!
Just back from two days of boondocking and two days of (electric only) camping.
Speaking as a full adult aware that scalding hot water will come on of the faucet I like it better without the mixing valve.
I used less water overall which might sound vague if not for the fact I save dishwater (cold) and add really hot water to it for new life. Also washing my face I'm able to get a decent amount of hot water in the sink bowl using less water overall.
Bottomline, don't try this at home with children. The water is quite hot. Next time out I'll bring a temp. gauge and measure it.
Old 04-08-2019, 05:38 PM   #10
2017 23' Flying Cloud
2018 25' Flying Cloud
Boston , Massachusetts
Replacing my mixing vavle
I have a 2018 FC fb twin and de-winterized it this weekend. Very little water pressure on hot side faucets. Posted on Airstream addicts and someone said the mixing valve on my Atwood XT HW heater is most likely plugged up. Emailed Airstream this morning and they confirmed this suspicion. Interestingly, they said they get a lot of calls this time of year when folks are de-winterizing. So, I am waiting for my mixing valve from amazon (and the flush wand) and in the meantime i have pulled up the plywood board covering the water heater and previewed my task ahead. The water feed from bypass tube and hot water outlet all unthread easily. I am guessing i will need a plumbers wrench to loosen the mixing valve from the heater itself? There are warning labels on the water heater cautioning that the mixing valve is not "serviceable" and changing the mixing valve can void the warranty. Has anyone captured photos/videos of this procedure they can share? I will also be flushing out the tank before replacing to try and get any remaining sediment from inside the water heater. Thanks!
ajpittman is offline   Reply With Quote
Old 04-08-2019, 06:27 PM   #11
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Atwood Mixing Valve
Yup me too. De-winterized yesterday. Spurt of hot water then just like warm / cold and reduced flow despite the tank being hot.
Iím still under warranty, I did call airstream this morning but they said a dometic authorized service shop would need to submit paperwork verifying the issue to get it covered under warranty.
No thanks, Iíll just do it myself, canít be bothered to spend time dragging the trailer into a dealer who has no time for me, only to break something else while servicing the unit.
I ordered a new mixing valve Atwood part number 90029 off amazon for $100 bucks this morning after my call with airstream (the did validate the part number for me).
2 days and the valve will be here and Iíll install myself.
Iíve got to remove the dinette bench and enclosure underneath to get after the valve. Itís just threaded in - hopefully comes out easily
ID:	337709   Click image for larger version
wulfraat is offline   Reply With Quote
Old 04-08-2019, 07:09 PM   #12
Senior Member
sheriff1's Avatar
Sparks , Nevada
Just completed this project. Donít order a new mixing valve yet!
Disconnect the cold water in and hot water out. Make sure pressure is released from system first. The silver portion will unscrew from the brass portion that is screwed into the tank. I used an old fashioned right angle adjustable wrench jut putting it on the body of the valve. That leaves the bronze portion into the tank, use a regular socket on that to remove, as I recall 1 1/8Ēsocket. Thatís where the problem is. This piece is the anti backflow valve and it has a screen on it that will be plugged with the white junk that forms in the tank. I had to clean mine a couple of times before I got rid of the white junk.
Old 04-08-2019, 07:49 PM   #13
BAB
BAB's Avatar
2015 30' Classic
I spent my $100 + and replaced my mixing valve last Spring. Then (as is often my habit), I decided to disassemble the old one to see ďwhat givesĒ after only 3 years. It was a bit of challenge to take it apart. It was (indeed) gunked up, primarily from passing a lot of hard water that left a nice deposit of minerals. Iím keeping it for a spare. Iím wondering if Iíll go to jail for this. It canít be too much more serious than removing labels from cushions
_________________
ProPride 3P
AIR# 58452
Old 04-08-2019, 07:53 PM   #14
This 6 gallon Atwood has a thermostat. Who can tell me what the factory default is and if there is a "A B C" setting?
Interstate Shower Head / Faucet / Mixing Valve nvestysly Sprinter and B-van Forum 15 10-23-2017 05:37 PM
2017 Classic Hot Water Mixing Valve Calibration rivetville 2016 - Current Classic (all lengths) 74 08-17-2017 04:20 AM
Shower Mixing Valve Cartridge Replacement jmellana Plumbing - Systems & Fixtures 2 07-29-2017 11:34 AM
Atwood XT Water heater mixing valve orloffgray Plumbing - Systems & Fixtures 0 03-23-2016 07:55 AM
Need mixing valve G. Traveler Sinks, Showers & Toilets 5 11-01-2011 06:15 PM
