11-01-2018, 04:53 PM
1991 29' Excella
Tulsa
, Oklahoma
Atwood Gas water heater won’t light
Our Atwood gas water heater won’t light and it doesn’t click like it normally does before it lights. Does anyone have any trouble shooting ideas? Attached is a picture, I’m wondering if we are missing a wire?
11-01-2018, 05:36 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
First thing I would do is check the ground. The screw in the upper left corner of the circuit board. Unscrew, clean, reinstall.
Second, check the contacts on the white multi wire plug connector at the circuit board. They are notorious for becoming corroded and not making connection.
Third, take a look a the 5 amp fuse to make sure it is good, check with a multi meter if you have one. It is the tan color object in the circuit board beside the ground wires/screws. It pulls straight out.
Alan
11-01-2018, 06:57 PM
2007 28' International CCD
Springfield
, Missouri
Order a Dinosaur circuit board to replace the substandard board with a high failure rate that comes standard in a Airstream.You will be glad that u did.While u are at it order one for the refrigerator also u will need that one before u know it.After that no more hassle.
11-01-2018, 08:01 PM
2000 25' Safari
Davidson County
The circuit board in the photo is not the original Atwood potted circuit board.
To me it looks like a Dinosaur board.... maybe.
ps: Also there is a Dinosaur board for the furnace, when it's time. I used one on my 25'.
Alan
11-01-2018, 08:15 PM
2022 25' Flying Cloud
NCR
, Ontario
pls search first
there are dozen of threads on this topic already
that is the only viable long term, working soln
don't waste your time asking dometic for a guaranty refund. they take 6 months if your lucky. AS support will not help either , as they just punt you to dometic
11-02-2018, 10:10 AM
2019 20' Flying Cloud
Eau Claire
, Wisconsin
Looks like you have a Dinosaur Board already installed, You must have gas pressure at the solenoids to have spark. Check the voltage on the solenoids if that is good and you have good ground I would talk to the people at Dinosaur.
11-02-2018, 11:21 AM
1991 29' Excella
Tulsa
, Oklahoma
Thanks for the suggestions. We tried them still no light
11-02-2018, 11:33 AM
2016 30' Classic
Victoria
, British Columbia
Does it look like the ground wire is broken off the right side porcelain insulator, or is it just the angle that the photo has been taken. If there is no ground, the spark from the igniter board cannot jump across the gap.
11-02-2018, 11:36 AM
Tom T
Orange
.... And while you're in there - check the pilot & gas nozzles & igniter area for spider webs & debris - clean the area.
The 2007 Atwood XT 10 gal 2-way that was put in our 1960 Avion T20 when restored back then, has been pretty reliable, except for the water mixing valve which needs service annually & replacement every few year.
So all this circuit board stuff must be a more recent issue with the Atwoods, & who knows where it will go going forward since Dometic bought them.
I do know that ALL of the excellent support webpages & documents were dropped by Dometic since April/May 2018 when I did the mixing valve replacement, when they switched everything to their new dumbed-down smartphone oriented website.
So all of their info on auto & pilot lighting issues was also dropped - but you may be able to get maintenance documents sent by Dometic emailed in pdf format if you contact Dometic directly.
I think that they had a how-to doc on troubleshooting your issue at the old Atwood website.
Cheers!
Tom
Tom T
Orange CA
1960 Avion T20, #2 made, Hensley Cub, TV tbd- looking for 08-22 Cayenne S, EH, etc
1988 VW Vanagon Westfalia CamperGL (Orig Owner) + 1970 Eriba Puck
11-02-2018, 06:34 PM
2016 26' Flying Cloud
Spring Lake
, Michigan
What is a Dinosaur board?
11-02-2018, 06:40 PM
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio
Brand name
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a great dog.
11-02-2018, 06:43 PM
1997 30' Excella
San Antonio
Don't have anything constructive to add as far as troubleshooting, however continuos failures like these prompted me to put a plain old light with a match gas/electric water heater in my '97 Excella when the original failed. Life is good. Lights everytime.
Bruce
11-02-2018, 06:54 PM
2000 25' Safari
Davidson County
Have you checked to see that power is actually getting to the water heater. There is a fuse or breaker in the 12v panel.
Alan
11-02-2018, 06:55 PM
2000 25' Safari
Davidson County
https://www.dinosaurelectronics.com/
Alan
11-02-2018, 07:01 PM
NCR
, Ontario
you do have the dinosaur board.
i suggest that you remove all the connections, spray with contact cleaner, use an old tooth brush and plug them in again
sound like a loose connection
11-02-2018, 08:13 PM
2000 25' Safari
Davidson County
Originally Posted by CruizinDux
Not applicable to the OP's water heater.
Alan
11-03-2018, 11:35 AM
1995 34' Limited
Vista
I had the same problem replaced the resistor that is covered by plastic tubing.....bought 2 for 12.00 at local camping world. I full time and no problem since
11-03-2018, 01:30 PM
2012 23' FB International
Woodstock
, Ontario
Airstream manual tells you to check the ground as first step in trouble shooting.
The picture shows an open board. My new Dinosaur board is potted (Sealed). I think yours looks like the one originally on my 1989 Excella.
The usual culprit if it is not a ground is, as mentioned, the multi wire plug-in that gets corrosion on the contacts. Try wiggling it; or tapping the board with a plastic screwdriver handle. If it is a touchy connection, you should then hear the spark. Otherwise start looking for a new board because that open one is subject to dirt and moisture contamination.
JCW
11-03-2018, 07:44 PM
1991 29' Excella
Tulsa
, Oklahoma
It was the regulator
Thank you all so much for all your help. We finally called out a mobile service to take a take a look (as we are camping our way to visit family in NC) and it turned out to be the propane regulator. I’m so thankful to have my hot water again
Once again, thank you for all your help!
