Old 10-03-2003, 05:11 AM   #1
Mike76251's Avatar
Atwood gas valve cost?
Hello All,
Does anyone know how much a gas valve for a Atwood 10 gal. should cost?
I need a new one 'cause I can't get my pilot to stay lit when I turn the gas control off light and to "run".
It is not my thermocouple BTW.
Mike
PS: Here's a pic of the current one,
Mike
Mike76251 is offline   Reply With Quote
Old 10-03-2003, 05:24 AM   #2
LOST , Hawaii
$90.50 from Mark's RV.
John
74Argosy24MH is offline   Reply With Quote
Old 10-03-2003, 05:46 AM   #3
Mike76251's Avatar
Thank you John!
I certainly hope a new one will last longer than the factory one did as it only had a couple of months use on it when it quit working (of course out of warranty).
Mike
Old 10-03-2003, 05:55 AM   #4
LOST , Hawaii
That's no good and it sure seems like it would last longer than that. I had a cheap catalytic heater that did the same thing. When I tore it apart it was full of a brown oil. Dealer told me it was the scent oil that they use for the propane smell. I just replaced the heater because it was cheaper than repairing, but I would check to see if it was something that had caused the valve to go bad.
John
Old 10-03-2003, 06:09 AM   #5
Mike76251's Avatar
John
Darn! Brown oil in a catalytic?
Those things can't take much of anything in the supply line or they clog up and stop working.
I would think it was your gas suppliers fault for adding too much sulpher (brown oil) to the gas.
It does give me a idea though to check for that in mine.
The thermocouple is putting out the correct amount of current in mine so it might be something else "plugged" up.
I will take it down shortly (since I am most likely going to get a new one anyway).
Thanks again,
Mike
Mike
Thetford valve rebuild mkeith54 Waste Systems, Tanks & Totes 17 10-15-2007 02:37 PM
Black & Grey valve trouble camphost Waste Systems, Tanks & Totes 51 08-18-2006 08:45 AM
servicing gas part of refrigerator nickcrowhurst Refrigerators 3 02-21-2006 07:46 AM
Gas Furnace ketchumwt Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-04-2003 12:46 PM
Followup to valve stem failure dtbw Wheels, Hubs & Bearings 0 10-29-2003 08:40 AM
