Old 06-20-2015, 09:17 AM   #15
1961 22' Safari
Collegeville , Pennsylvania
If your inlet and outlet are at the top of the photo then your bypass valve is on the wrong side.
It needs to be before the inlet valve and after the outlet valve.
Right now water is flowing into the heater and through the bypass valve to the hot side. So it's not bypassing anything.
Closing the bypass valve will make water go through the heater, but you still don't know what's causing the blockage.
TheHandyDan is offline   Reply With Quote
Old 06-20-2015, 03:09 PM   #16
1966Florida's Avatar
1966 26' Overlander
Orlando , Florida
PROBLEM SOLVED- THANKS GENTLEMAN!!
I cut all of those valves in the clear and started from scratch. Rebuild the inlet and outlet from the tank itself- works great. - ALmost bit the bullet and spent $375.00 on a new hot water heater.- Could not have solved this w/o your help!!!
1966Florida is offline   Reply With Quote
Attwood Water Heater... Trouble Shoot... Lothlorian Water Heaters, Filters & Pumps 9 12-31-2009 12:22 PM
Black Water Tank Valve Open but no Flow... dbaverb Waste Systems, Tanks & Totes 20 07-15-2009 09:19 AM
19 Gal Black Tank Upgrade to 39 gal? Old_Town Waste Systems, Tanks & Totes 6 07-17-2007 03:21 PM
10 gal in a 6 gal Hole aviontt Water Heaters, Filters & Pumps 18 12-19-2003 06:23 PM
