Hi, I just typed this entire message in, and while I was waiting for my phone to upload the pics my Airforum timed out and it all vaporized. How convenient. So I'll be brief, no pics.
1987
Sovereign, 25'. My water heater has an "Arctic Pros" bypass unit. Rectangular box, about 3" by 2" with a single 90 degree valve handle. Two positions - Bypass and Normal Flow. I'm pretty sure it is a cartridge valve inside that will isolate the inlet to the water heater from the water system and isolate the outlet of the water heater from the system, and bypass the inlet to the outlet to allow those that winterize by adding antifreeze to drain the water heater separately and not add as much anti-freeze. I blow my entire system out every winter, including the pump, water heater, all fixtures, etc. I never bypass my water heater. Anyway, a leak developed on my Arctic Pros unit. It's dripping from the box itself, not any of the threaded connections to/from the box. I cannot find a replacement or any info about this unit anywhere, so I'm thinking of just making up a 3-valve manifold. Anyone else deal with one of these? Thanks.
