Old 09-01-2014, 10:34 AM   #1
1978 Argosy Minuet 6.0 Metre
Richfield , Wisconsin
Argosy issues
Have a very nice , I think, Argosy 26.. Two problems: one the water pump just stopped working Worked fine on Friday and Sat morning. Then Sat afternoon .... nothing.. What do I check beyond the fuse on the unit, which I replaced and checked all main fuses.. No noise from the pump. Plenty of water
Two my curbside access door blew/fell off... It was already broken and had to use duct tape to keep stuff in and the elements out. Any ideas for either relacement or what material to make a temporary/permanent door??
rvrzal is offline   Reply With Quote
Old 09-01-2014, 10:44 AM   #2
1977 Argosy 24
Milltown , Wisconsin
Are you sure the pump didn't just get turned off from the switch behind the kitchen sink? If not, get a 12 volt test light or a multimeter and see if you have 12 volts at the pump. If not start by testing of voltage at the switch and go from there.
ventport is offline   Reply With Quote
Old 11-07-2014, 10:35 PM   #3
Athens , Georgia
rvrzal, I have a 78 ARGOSY Minuete, which access door blew off? The refrigerator vent door? If it is completely gone and you will be using the trailer, I would look at using sheet aluminum to remake an access door, but it should be vented but water-shedding. If you are done for the season maybe a piece of plywood cut to size and sealed in place would do? Is the hinge still there? I have a 10ft roll of thick plastic sheet I got from the hardware store. It is sturdy, and easy to shape/cut. Nascar guys use it for panel repairs during races, and I used it to reinforce/rebuild my plastic tub wheel wells. I hope this helps...
MIKO92 is offline   Reply With Quote
Propane line routing issues - Argosy MH bkahler General Motorhome Topics 12 03-29-2013 06:47 PM
Crazy Argosy 12V issues! mtbguy Electrical - Systems, Generators, Batteries & Solar 7 02-05-2013 06:29 AM
VIN#/Registration/Tag Issues for an Argosy- Help! ArtWithin Title, VIN & Registration 0 07-11-2012 01:18 PM
Radiator issues on Argosy MH birdsurfs Mechanics Corner - Engines, Transmission & More... 2 07-07-2012 03:46 PM
Alarms, remotes, and other security issues. Griffin Airstream Motorhome Forums 19 02-12-2003 11:57 PM
