Old 11-23-2002, 10:51 AM   #1
Kistler's Avatar
2002 25' Classic
Oro Valley , Arizona
Aquajet noisy? Why no more 3-way refrigs?
New to Airstream trailering .... just purchased a new (2002 model) in late October......have noticed that the waterpump is noisier than the one in my now-traded Jamboree.
Are Aquajets noisy? Had a SurFlo in the Jambo, I think. Also after I shut off the pump, I hear a strange growling, gurgling sound for about a minute when leaving the faucet open to relieve stress????? Is something wrong?
I think the last time we had a three-way refrigerator was in our Vacationeer 5er......Jambo didn't have it.....Airstream doesn't either. Why did they quit that refrigerator setup?
Sorry about the mix of questions; I have a lot more but will save them for later.
Kistler
PS--anybody reading this in the Southern AZ unit of WBCCI?
Kistler is offline   Reply With Quote
Old 11-23-2002, 11:47 AM   #2
JPAIRSTREAM's Avatar
1972 31' Sovereign
, Ohio
Images: 47
Call Airstream on your pump it is under warranty. it could be air in the lines..
JP
JPAIRSTREAM is offline   Reply With Quote
Old 11-23-2002, 06:44 PM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Kistler!
I don't know whether the 3-Way refrigerator is an option for new Airstreams or not, but assume that it must be as my Airstream dealer had one in-stock for replacement. When it came time for a new refrigerator in my '64 Overlander, I chose a 3-Way Dometic and couldn't be happier - - I too had one in a 1980 Nomad that I owned and had missed the travel convenience of 12-volt operation. The new units with Automatic Energy Selectors are really nice - - my 1980 coach had manual controls but the new unit installed in my Overlander has fully automated controls.
Kevin
Kevin D. Allen
AIR #827
Old 11-23-2002, 06:51 PM   #4
Kistler's Avatar
2002 25' Classic
Am happy you two replied....because know nothing here....I wasn't/didn't have opitions...it was in stock.....like I say my wife wandered around the lot....yikes.. cost about 14,000 more than a Safari which we went to buy...
It is just strange after 9 years of a "demand" system to hear all these strange noises....part of the prob is I expect the Airsteam to be PRETTY Perfect for the price.
Kistler Ryan
Tucson
Old 11-24-2002, 08:00 AM   #5
lynn's Avatar
Cool
Your Aquatec pump is a higher volume pump . There is a set screw (allen) on the head of the pump that can be adjusted which will adjust pressure and reduce noise. Also a 12" flexible hose can be added at pump to reduce vibration. Your pump is probably working fine.
lynn is offline   Reply With Quote
Old 11-24-2002, 09:23 AM   #6
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
I also miss the three way refrigerators. I don't see them being installed anymore in new SOB units either. I guess it had a lot to do with the draw on the battery.
I used to travel with the 12 volt side on in my old Hi-Lo. The only problem was occasionaly the feed in the Bargeman outlet would not be making good contact and I would get to my campsite with a dead battery....and guess what, if the battery was dead the top on the Hi-Lo wouldn't raise. I soon learned to turn on an inside light when I hooked up. If it brightened up upon connection to my tow vehicle, I knew I had a good connection.
Jack
Jack Canavera
STL Mo.
AIR #56
noisy refrigerator fan Turtle 1997 - 2004 Bambi 9 06-03-2004 04:45 PM
Aquajet vs. Shurflo Silvertwinkie Water Heaters, Filters & Pumps 14 08-29-2003 07:49 AM
noisy water lines kooblekidz Airstream Motorhome Forums 1 08-03-2003 02:35 PM
Fantastic fans very noisy - wore out? ipso_facto Roof Vents, Skylights & Fans 5 07-17-2003 07:47 AM
