Old 08-01-2014, 08:06 AM   #1
2008 23' Safari FB SE
Boulder , Colorado
Anyone replace OEM aquatic II water pump with Sureflo Revolution?
Has anyone replace OEM aquajet II water pump with Sureflo Revolution? Is it a straight and simple swap using existing wiring connections and screw mounting locations?
What are the best connectors to use for the wires? Our dealer just used electrical tape for the old pump.
bonginator is offline   Reply With Quote
Old 08-01-2014, 09:06 AM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Water pump replacement is straight forward procedure. The SurFlo Revolution is a good choice. I just replaced my old pump with the SurFlo.
The water connections are basic 1/2 plastic pipe threads with elastomer seals. The 12v wire are best connected with crimp style connectors. Some folks use wire nuts. Then screw the pump to your subfloor. You don't have to use the old hole pattern. The pump comes with rubber feet for noise and vibration reduction.
The only difficulty is working in the tight confines where the pump may be located.
David
replace OEM with satellite dish boondockdad Audio, Video & TV 4 03-18-2012 05:23 PM
Thoughts on Revolution RV? AronS Trailer Values 15 09-26-2008 04:04 PM
