Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 06-30-2006, 11:47 PM   #1
volvophile
volvophile's Avatar
Profile:  colorado springs , Colorado
any way to set water temperature in an Atwood HW heater?
Hi There.
I finaly shoe-horned a newer 10 Gallon Atwood DSI into the '63 and tested it today.
It all works, maybe a little to well, that water comes out HOT!
I have small kids so would like to modify it to shut off at 120 degrees.
Also wouldnt mind saving the propane a little to by going with a lower temp.
Has anyone had any luck in this mod?
Like putting a resister in series or parralell with the temp sensor or something sneaky like that?
volvophile is offline   Reply With Quote
Old 07-01-2006, 06:54 AM   #2
flyfshr
ModeratorMan
flyfshr's Avatar
Profile:  1959 24' Tradewind
Phoenix , Arizona
I know what you mean. The water practically comes out of the faucet boiling. My Suburban 10 gallon WH has an adjustment at the unit and its set to the second to the lowest setting. I would think Atwood's would have a similar adjustment. Maybe time for the manual?
FF
WBCCI/VAC #2699
Air #10
I'm haunted by aluminum.
http://www.airztream.com
http://59tradewind.blogspot.com
flyfshr is online now   Reply With Quote
Old 07-01-2006, 07:11 AM   #3
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 58
The 6 gallon Atwood in my 75 TW has a lever that is located on top and behind the control unit. Slide it left for cooler water and right for hotter. When at the mark at dead center it is "just right".
Richard
Charter Member Four Corners Unit
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Tankless water heater spinolio Water Heaters, Filters & Pumps 3 12-21-2002 09:53 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
hot water heater Mary Water Heaters, Filters & Pumps 2 08-12-2002 09:15 AM
lighting water heater susan martin Water Heaters, Filters & Pumps 2 07-27-2002 10:13 AM
