Old 07-05-2011, 12:38 PM   #15
1973 31' Sovereign
Portland , Oregon
Images: 22
My radiant heating system...
I recently started a thread to document the radiant heating system that I am in the process of installing in my 1973 31' Airstream. For anyone that is interested you can read about it here:
http://www.airforums.com/forums/f163...ion-78761.html
I am using a tankless water heater mounted externally that can produce something in the range of 65,000 BTU of heat energy. The system is a simple open-loop radiant system where the hot water is shared between domestic hot water and hot water for heating. The pump that I pointed to above is part of the system and is responsible for move the hot water for heating around through the tubing in the floor.
I kept my system as simple as possible for economic reasons as well as for over ease of installation. See what you think...
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
malconium is offline   Reply With Quote
1968 Airstream hot Water and Furnace mpovah 1959-69 Tradewind 6 03-16-2012 11:14 AM
Hot Water heater trmiller Water Heaters, Filters & Pumps 5 07-05-2011 05:48 PM
No Shower Hot Water KerriO Plumbing - Systems & Fixtures 15 05-29-2011 04:48 PM
120 vs 140 degree hot water darryl97420 Water Heaters, Filters & Pumps 3 05-24-2011 05:52 AM
Hot Water from Cold Valve txhippiefish Fresh Water Systems 26 04-03-2011 11:05 AM
