Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 02-03-2008, 03:31 PM   #1
SilverCabin
SilverCabin's Avatar
Profile:  2007 23' Safari SE
Viera , Florida
Question Anode Rod
Camping World has a sale on Anode Rods for Suburban and Atwood water heaters. According to my documentation, my 6 gal. Atwood water heater doesn't have one. The Camping World ad says to remove the plastic drain plug and replace it with the Anode Rod to extend the life of the water heater.
Is this something we should do, add an Anode Rod to the water heater?
Randy
Randy and Pat Godfrey
2nd VP Florida Unit
WBCCI# 7591 - AIR# 17017
2007 Safari SE 23' - Daisy
2006 Lincoln Mark LT - Hoke
Read our Travel Blog at: www.silvercabin.net
A journey of a thousand miles, begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 02-03-2008, 03:57 PM   #2
2airishuman
2airishuman's Avatar
Profile:
Originally Posted by SilverCabin
... remove the plastic drain plug and replace it with the Anode Rod to extend the life of the water heater...
have u read the shampoo bottle directions...
"wet, apply shampoo, lather, rinse....
and REPEAT"
it is my understanding the newer atwoods have an aluminum tank, not steel.
no anode rod is needed or recommended for these alum tanks...
my approach is to remove the water heater plug monthly and rinse out the tank solids...
it takes about 5 minutes to do, including the time to drain the tank...
but i also filter ALL water going into the 'stream for chlorine, iron, sulfur, minerals and other elements that can interact with the tank...
new plugs and silicone tape are cheap, so i carry several...
for folks with steel tanks the rods may be helpful, since they provide the sacrificial element...
but even these need to be removed regularly and the tanks flushed...
and with the cost of replacing the rods annually, i'm not sure any money is saved over the long term...
steel tank faq #4...
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 02-03-2008, 04:03 PM   #3
SilverCabin
Viera , Florida
Rinse Periodically
Thanks 2air.
I did see the rinse instructions. Since mine is 2006 vintage, I suppose I have the aluminum tank. Thus, save the money and rinse periodically.
Couldn't find anything in the Forums on this, so I thought I would pose the question for all.
Randy
2nd VP Florida Unit
Old 02-03-2008, 04:17 PM   #4
2airishuman
Profile:
hi randy
i seem to recall the aluminum tanks are 'lined' with something that eliminates the need for an anode rod...
in addition the tanks threading is aluminum...
while the anode rod is steel or brass?
so IF you did use one silicone tape would be an absolute requirement,
to avoid galvanic welding of the rod to the hole...
the plastic plugs atwood uses don't require tape,
but i've found using it sometimes stops a dribble at the threads...
for RINSING the water heater tank, there is a cheap yellow hose head wand gizmo that works...
cw sells them and we've posted pictures of it back somewhere...
cheers
2air'
Old 02-03-2008, 04:40 PM   #5
lewster
Commercial Vendor
lewster's Avatar
Profile:  2006 19' International CCD
Marco Island, FL , Hood River, OR
Not bad Joe.......but here's the actual skinny on the subject:
No, Atwoods DO NOT HAVE AN ANODE ROD and adding one to your Atwood will void your warranty!!!!!!!!!!!! I have no idea why CW sells one, as they won't do a thing to the lined tank of an Atwood. It's just like the 'Hott Rodd' that they sell to make an LP only heater into an LP/electric model. Some folks use them....but again......IT WILL VOID YOUR WARRANTY.
Further, these devices are usually UL rated, and if it is rated only as an LP device.....adding 120VAC to it will void it's UL rating. If you have a fire and it's caused by the device that you added guess what...... NO INSURANCE COVERAGE!!!!!
BTW, you should always add a thread sealant to any plastic threaded fitting unless it is a compression fitting or has a rubber gasket or saniprene seal on the end......in which case you never add anything to the threads as they do not accomplish the sealing; the gaskets or compression ring do the sealing.
Also, the anodes that Suburban uses on their water heaters are magnesium and yes....they should have pipe sealant or tape on the threads.
Rinsing is also recommended for ANY water heater. Get all of the crap out of the tank......it might take 2 or 3 rinses. It will definitely prolong the life of your tank!
Lew Farber - contact
Certified Master RV Tech
BACK IN THE 'HOOD' FOR A WHILE !!
"Laissez Les Bon Temps Roulez"
www.islandmetalworks.com
WBCCI #1032/VAC (assoc) #1032
AIR # 10325
CHARTER MEMBER: FOUR CORNERS UNIT
Old 02-03-2008, 04:55 PM   #6
2airishuman
Profile:
tanks lewster!
the rod is magnesium but how about the threading ?
i get the sealant guide but here the...
tanks threading is aluminum and the plug is plastic (butyl)
no gasket and not a compression fitting, but it does expand/compress a little from the hot water and pressure
so tape on the plug yes/no?
cheers
2air'
Old 02-03-2008, 06:08 PM   #7
lewster
Commercial Vendor
lewster's Avatar
Originally Posted by 2airishuman
tanks lewster!
cheers
2air'
You're vulkem!
I always tape plastic threads with the listed exceptions, especially when going into metal threads so......................YES! DO IT!!!!! You'll be happy you did!
AIR # 10325
Old 02-03-2008, 07:30 PM   #8
guskmg
"SPACE A"
Profile:  2006 34' Classic
Fort Worth , Texas
The aluminum tank will corrode, but a sacrificial zinc anode will prevent this from happening. The white stuff you flush out is residue from prior corrosion, but the tank is still being attacked and has corrosion attached to the surface. One day a hole will form where the corrosion has eaten through the tank wall. Notice that all Mercury outboard and In/Out drives use a zinc anode just above an aft of the propeller. Observe, depending on the water's ingrediants, some with severe sacrifice. Steel tanks can use magnesium anodes for the same purpose of protection.
Gus
Old 02-04-2008, 09:54 PM   #9
SilverCabin
Viera , Florida
Thanks Lew. That's pretty clear!
Randy
2nd VP Florida Unit
Hott Rod trailermom Water Heaters, Filters & Pumps 0 10-21-2006 08:23 AM
Use of Hott Rod? desidou Water Heaters, Filters & Pumps 1 06-07-2005 08:40 AM
Atwood Bowen anode rod? Moonshot Water Heaters, Filters & Pumps 3 11-11-2003 08:37 AM
Hott Rod & Lightnin' Rod femuse Water Heaters, Filters & Pumps 6 09-22-2003 12:46 PM
Checking the Anode Rod... ALANSD Water Heaters, Filters & Pumps 1 05-08-2002 09:23 AM
