Old 12-19-2008, 10:58 AM   #1
1972 25' Tradewind
Madison , Wisconsin
Anode going AWOL
Anyone have any idea as to what causes the clay to come off of a water heater anode. I am assuming that I must have hooded up something wrong. The heater sat in the box for many months. There was water in the heater and system for several days when I tested the new plumbing. The heater got tepid during a short AC test and heated up fine on gas.
When I drained the system I found a lot of clay like substance in the bottom of the water heater, and the anode rod was all pitted. The metal in the rod does not look corroded.
I sent an email to Suburban inquiring about the problem but never heard from them.
This spring I will go through the system but thought it may save some time if someone else had run across this
ID:	72723   Click image for larger version
Smokin Camel is offline   Reply With Quote
Old 12-19-2008, 11:45 AM   #2
1994 30' Excella
Mississauga , Ontario
Is that an anode rod or an electric heating element to heat the water on 110?
AL
Old 12-19-2008, 12:40 PM   #3
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
When I winterized our 69 this fall it had a brand new suburban water heater. I noticed a fair amount of pitting like yours, not near as much up by the threads though. Might be best to flush the bottom of the tank and replace the rod, could have been defective, or you might have had some pretty strong water at a camp ground or something too. Our local ACE hardware had the anode rod, think they were 5 or 6 bucks to replace, so we just swaped it out.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is online now   Reply With Quote
Old 12-19-2008, 01:29 PM   #4
Images: 59
I've never seen an anode go that fast, in just a few days.
I suspect that you have a case of stray current corrosion, which only happens in proximity to DC current sources, and can happen much more rapidly than normal galvanic corrosion.
Check all your DC wiring to be sure there isn't a wire brushing against the water heater, frame, or associated piping.
Old 12-19-2008, 05:21 PM   #5
cammur's Avatar
Roseville , California
Looks like the electric heating element I just installed in my Atwood as an add-on. I have no experience with it and it won't get tested until January, but I agree it shouldn't naturally deteriorate that quickly. Hopefully markdoane tagged it right and you have a simple cure. Let us know what you find.
Cam
2005 25' Safari SS
2005 Dodge Ram 2500 Turbodiesel
WBCCI #3580 - Region 12 NorCal
AIR #8752
Roseville, CA
cammur is offline   Reply With Quote
Old 12-20-2008, 10:30 PM   #6
1972 25' Tradewind
Madison , Wisconsin
Dc
The DC is also one of my main suspicions. It was good to know it occurred to someone else. It is the anode rod, not a heater element. Thanks for all of the input...any ideas are welcome, it will save me a lot of trouble shooting (hopefully).
Old 12-25-2008, 11:04 AM   #7
1972 25' Tradewind
Madison , Wisconsin
heat element - annode?
AL
I meant to repond to this awhile ago--
I thought it looked like a heat element. I checked the manual & the hole I took it out of. According to the manual the rode came out of the anode hole on the Suburban 6WDE. I am mystified, but suspect the wiring needs to be rechecked for shorts.
Anode Rod SilverCabin Water Heaters, Filters & Pumps 9 02-17-2009 10:23 AM
Zinc anode henw Water Heaters, Filters & Pumps 7 04-19-2008 09:11 PM
General's gone AWOL again Boondocker On The Road... 61 01-09-2008 01:35 PM
The general went AWOL Boondocker On The Road... 54 08-01-2007 12:13 PM
Checking the Anode Rod... ALANSD Water Heaters, Filters & Pumps 1 05-08-2002 08:23 AM
