Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 11-01-2006, 03:00 PM   #1
kamo
kamo's Avatar
Profile:  burbank , California
air pump vs water pump
Hello,
In my '62 Bambi there is an airpump connected to the water tank, to provide water pressure.
Should I keep this design, or upgrade to a new water pump?
(This question might answer itself soon, as I have never tested if the air pump works.)
Kamos
kamo is offline   Reply With Quote
Old 11-01-2006, 03:15 PM   #2
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
An air pump can only be used with the stainless steel tanks. If you are replacing your old tanks with new plastic ones, you will have to change out the pump too. You can't use an air pump with a plastic tank.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdie
Old 11-01-2006, 03:16 PM   #3
dwightdi
Profile:  1977 31' Sovereign
McHenry , Illinois
I changed mine out on my 63. Did not like the idea of having the water pressurized all the time because of potential leaks. It is a pretty small compressor and takes some time to pressurize the system if you leave it off most of the time. You also can not add water to the tank when the tank is pressurized. The pressure seal cap on the side of the unit also required you to also open a vent and both became a little difficult if not lubricated properly.
Old 11-01-2006, 06:55 PM   #4
kamo
kamo's Avatar
It's the original system, but the tank looks like it's galvanized, not stainless steel.
I think I'll just get a water pump. Any suggestions on make/model?
Old 11-01-2006, 07:17 PM   #5
dwightdi
McHenry , Illinois
I had an extra PAR but most people the newer shurflow that does not make as much noise. You still have to rubber mount them and have a rubber tube section between the pump and the tank and the pump and the rigid waterlines for the best sound isolation.
Old 11-01-2006, 07:44 PM   #6
markdoane
Profile:  , Minnesota
Images: 59
I've heard of galvanized tanks,and mine was aluminum. I don't think they were stainless-that would have been pretty high end in 1959-62.
I got a Flojet VSD pump, I don't know if it is quieter than the Shurflo but it's pretty quiet.
Non-contributing deadbeat.
Old 11-01-2006, 09:13 PM   #7
CaddyGrn
Profile:  1963 16' Bambi
Yreka , California
Keep the pressure up! :)
We have a 63 Bambi with the original water system. Love it! The galvanized tank is great, no plastic tasting water here! I really like the pressure system. Ours works well and the pump will work about 3 different times before we run out of water.... so I know when the pump starts for the third time I can figure one more dish washing and meal....
It does take a little while, but the pressure system doesn't have to come on in the middle of the night and wake everyone up when the water is used!
We have a little shrader valve on the outside of the neck of the water fill pipe so if our little compressor quits we can use one of those little tire compressors that plug into your cig lighter to pressurize the tank.
If all works, I would try it out first and see what you think! I have had the other types with plastic tanks (yuk!) and the water pump that comes on each time you turn on the faucet.
The original is simple and works well. No new wiring or installation.
Mrs. NorCal Bambi (traveling in S Tardis)
CaddyGrn is offline   Reply With Quote
Old 11-01-2006, 10:19 PM   #8
kamo
kamo's Avatar
OK, then I'll test it this weekend. I just have to make sure there's no shorts and hookup the battery.
Old 11-01-2006, 10:33 PM   #9
Mark Wiltrakis
Silver Hilton
Mark Wiltrakis's Avatar
Profile:  1992 29' Excella
1959 24' Tradewind
Hillsboro , Oregon
Question for markdoane
Don -
Did you keep your original aluminum fresh water tank? Mine looks great, seems to have no leaks, and I like its looks. The filler neck interior looks crusty, and I know not what lives in the tank itself.
Can I clean up the original and keep it in service somehow? This, with a modern 12 v water pump, would be my preference. On the other hand, I'm no fan of the taste of aluminum foil.
Mark
Mark Wiltrakis is offline   Reply With Quote
Old 11-01-2006, 11:18 PM   #10
scottanlily
Profile:  1960 24' Tradewind
santa barbara , California
The tank in our 60 trdwnd was aluminum with the red Grover pressure pump
(they still make them )and the tank was trash inside due to corrosion of the aluminum from the water inside ,you need to remove the outside faucet bib cap and get a light to see inside ,if its purely clean your happy ,if its got granulated crud in it its no good .I had a new stainless steel tank made for
it ,round as original same length and all using stainless fittings matching the original design ,I can go to a modern water pump also if I like but this setup
works good ,you can take a shower if the pressures up ,not super great but
great enough if want to and we have done it before camping . we also have the outside air fitting to pressurize the tank should the 12voltpump fail you still can use an external compressor or a tire pump as was the original idea
for boondocking (that would be some work )yes .Mark W is right about the aluminum taste ,not healthy remember that ,A better idea to use a water filter after the tank .We drink bottled water and showers and dishes and such with the tank water ,but Ill drink it if needed ,its stainless steel anyway.
Scott
scottanlily is offline   Reply With Quote
Old 11-02-2006, 05:04 AM   #11
markdoane
Images: 59
Originally Posted by Mark Wiltrakis
Don -
Did you keep your original aluminum fresh water tank. . .
Mark
I replaced the tank with plastic because I wanted a little more water on-board. The old tanks only hold about 18 gallons, without the air blanket. The new tank is 28 gallons and was a pretty tight squeeze behind the gaucho. I still have the old tank, compressor and fittings. I may use them somewhere else.
The tank looks solid. I don't know what the inside looks like. I wouldn't use it for drinking water, because I couldn't be sure about the quality of the water. You might also get a little oil blow-by from the compressor.
Old 11-02-2006, 09:09 AM   #12
NorCal Bambi
NorCal Bambi's Avatar
Yreka , California
Images: 21
pressure tank
I have to go along with my wife. We really like the pressure tank. I was able to inspect the inside of the tank by soldering long wires to a auto light
bulb
and then removing two of the fittings on the tank.
dropping
the light down into the tank gave me a good visual inspection of the tank. It was also a good method to help me clean out the tank. I then used a very long hose on my compressor to check the tank with pressure. I had it a long way away from me during this test. And I was behind the building during the test. If the tank exploded I wanted to be a long way away. I let it set for several hours during the testing. Yes, It is
noisy
when it runs. I think part of the
problem
is that the shock
mount
rubbers are old and hard. I haven't looked into replacing them yet. My guess to why they have be replaced by water pumps is that the tanks are very expensive to replace today. When the pump goes off, and someone asks, "What is that", it opens a whole new avenue of Airstream conversation. Something
Airstreamers
seem to enjoy. At 3 a.m. when I have to use the head, it nice to not wake my wife with a
noisy
water pump.
Don
NorCal Bambi is offline   Reply With Quote
Old 11-02-2006, 09:11 AM   #13
NorCal Bambi
Yreka , California
Images: 21
Well that was interesting. I use the spell check that comes with Foxfire. I don't think I'll do that again.
Don
Old 11-02-2006, 09:17 AM   #14
Sugarfoot
Sugarfoot's Avatar
Southeastern Area , Tennessee
I also still have and use the original aluminum tank. No crusties, no leaks, clean and was in great shape. But I do like Scott. Bottled water for human consumption and the tank for everything else. It's still on my list to get tested the water contents and quality of what comes out of the tank, but low on the priorities. Now, just need to get my Grover working properly.
• • • Aluminocentricity • • •
Sugarfoot is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
Water Pump Joan D'Andrea Water Heaters, Filters & Pumps 3 11-01-2002 06:31 AM
Water pump has quit roessler Water Heaters, Filters & Pumps 8 08-14-2002 03:02 PM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
