Old 11-14-2006, 08:52 PM   #21
1960 24' Tradewind
santa barbara , California
1959newbie,
I checked out Grover ,their newer version (very much the same ) is
part # 1167 12 volt pump ,it would need a 45 psi cutoff switch ,easy to get.
they didn't show the price ,but J.C.Whitney has the same Grover compressor
is 199 dollars , part # ZX754712W still pretty high ,but cheaper for sure than 400 bucks. I still will be working on a better solution for you .
Back to you soon
Scott
scottanlily is offline   Reply With Quote
Old 11-15-2006, 12:32 AM   #22
1959newbie's Avatar
Hill Country , Texas
Thanks for your help, Scott! I'm still looking, too.
Lynne
1959newbie is offline   Reply With Quote
Old 02-27-2008, 03:01 PM   #23
bevman's Avatar
1958 22' Flying Cloud
Saint Helena , California
Hello all. I've just rebuilt my Grover pump (no oil -- siezed up -- cleaned, added oil to crankcase) and it works fine except the pressure control won't shut off the pump. It pumps up to 70# and I get nervous and shut it off. I've backed the adjusting nut that sits atop the spring in the switch to the end of the threads. Still runs. I can force the arm with a screwdriver and make the switch shut off the pump.
Could it be the diaphragm? Can they be replaced, or do I have to buy a new pressure switch? The brand of the switch is "Lic" (that's the logo on the switch cover). Google doesn't help me find them. There might be a Square D brand that would work, but which one? Or would a Square D rebuild kit have the diaphragm that I need?
bevman is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 06:16 PM
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 07:11 AM
Water Pump Joan D'Andrea Water Heaters, Filters & Pumps 3 11-01-2002 07:31 AM
Water pump has quit roessler Water Heaters, Filters & Pumps 8 08-14-2002 04:02 PM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 11:35 AM
