Old 01-11-2007, 03:32 PM   #1
nilesrob's Avatar
Marietta , Georgia
Images: 12
Air in hot water
I am getting air in our hot water. I have diagnosed the air leak to be somewhere (seemingly) in the hot water heater.
If I run cold water, no air - works great. If I run hot water but bypass the heater, no air - works great. If I run the hot water lines as they should with water circulating through the hot water heater, I get a lot of air in the water.
I have checked the hot water heater drain, and that appears to be fine. Any suggestions? Thanks.
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 01-11-2007, 03:50 PM   #2
rseagle's Avatar
2004 22' International CCD
Spotsylvania , Virginia
Images: 33
Have your pressure relief valve checked! As water heats up, oxygen bubbles out. The PRV is suppose to release the air.
"THE BAUXITE BUNGALOW"
2004 22' CCD
1997 F-150
TAC VA-12
AIR# 4749
ex WBCCI# 1430
rseagle is offline   Reply With Quote
Old 01-11-2007, 05:19 PM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Try to use the heater by pass and see if it still happens. If so, the issue is somewhere away from the heater.
Dumb question, but you did flush the whole system out right? I get lots of air until I flush the whole system out.
Old 01-11-2007, 06:03 PM   #4
nilesrob's Avatar
Marietta , Georgia
Images: 12
I tried turning on the heater bypass, and the air in the water stops almost immediately. It seems to be something going on within the heater.
The Slowsky's
WBCCI #1271
Old 01-11-2007, 06:58 PM   #5
72 tradewind's Avatar
1972 25' Tradewind
Willis , Texas
Images: 8
air leaks
You should have a water leak also. I have seen bubbles in my hot water but consider it normal as I have no water leaks.
72 tradewind is offline   Reply With Quote
Old 01-11-2007, 08:12 PM   #6
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
Just a suggestion.
Turn off the water pump, and unhook from city water.
Drain the hot water heater.
Put in the plug, leave the water heater turned OFF. Hook up water or turn on the pump. Open all the hot water outlets, and let them run until water runs a solid stream. Turn them off, and turn on the farthest from the hot water heater to ensure there is no air escaping. If all seems well, then turn on the hot water heater, and then check 30 minutes later.
Takes a little while, but it's free!
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 01-13-2007, 09:49 AM   #7
nilesrob's Avatar
Marietta , Georgia
Images: 12
Originally Posted by steelbird312
Just a suggestion.
Well, that there is the complete solution! Thank you Steelbird and everyone else - problem solved.
The Slowsky's
WBCCI #1271
Old 01-13-2007, 10:46 AM   #8
1956 22' Safari
Images: 11
I Lied!!!!!!!!!!!
Nilesrob,
I lied just a little bit about it being free. If we are ever at the same place at the same time, you owe me a blizzard!
jerry
steelbird312
1989 29' Excella
Atwood water heater uwe Water Heaters, Filters & Pumps 5 10-03-2009 01:58 AM
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Low water pressure in Excella murf Fresh Water Systems 7 09-04-2002 07:12 AM
Faulty Emerson RV E-330-5 Hot Water Dispenser winner Water Heaters, Filters & Pumps 4 08-02-2002 02:07 PM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
