Old 06-26-2010, 01:34 PM   #1
tbettes's Avatar
1960 26' Overlander
1962 16' Bambi
Smithville , Texas
Adjusting gas/Air Mixture
After searching this forum I feel lucky my problem is small compared to many. When the water heater lights, the exhaust has some amount of carbon in it, enough to create a trail up the side a few inches after a while. I have tried adjusting the air mix portion of the tube going in but since I am not sure how or what direction to move it, I thought it would be wise to seek the wisdom of the many more experienced people here. How do I adjust the mixture?
Tom
tbettes is offline   Reply With Quote
Old 07-07-2010, 06:44 AM   #2
tbettes's Avatar
1960 26' Overlander
1962 16' Bambi
Smithville , Texas
Smile Air Mix
I was told by a friend who seems to understand and know everything mechanical that I should increase the air content until the flame has no yellow, only blue. I maximized the air and the flame is almost all blue except at the end. The carbon has almost completely stopped. Hopefully this will help someone.
Tom
Old 07-07-2010, 07:04 AM   #3
raveson's Avatar
1989 34.5' Airstream 345
boca raton , Florida
not just water heater
Make a note to check your other gas appliences. The same blue flame applies.
raveson is offline   Reply With Quote
Skittish pilot light/mixture in a 79 NT30-MP gonorthwest Furnaces, Heaters, Fireplaces & Air Conditioning 1 12-13-2009 08:24 AM
Adjusting WD Hitch to Air Suspension dpulling Hitches, Couplers & Balls 4 08-06-2009 10:49 PM
Adjusting gas pressure nsteel Refrigerators 3 05-26-2009 08:26 PM
suburban furnace air mixture control? thatscool Furnaces, Heaters, Fireplaces & Air Conditioning 11 11-29-2008 07:56 PM
? about air preasure at gas stations... crazylev Tires 31 06-04-2006 07:28 AM
