Old 02-11-2015, 03:24 PM   #1
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Adjustable thermostat
Does anyone have any actual experience with the available Atwood water heater adjustable thermostat? Installation, reliability, etc. My water gets too hot for my sensitive side and other extremities.
MICHAEL
Old 09-24-2015, 11:10 PM   #2
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Michael,
I see no one answered your question. I'd like to hi-jack and join in asking if there is a good way to control the temp. of our Atwood Water Heaters?
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 09-24-2015, 11:44 PM   #3
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Hey guys, Atwood makes sensors with different temp settings, plus the adjustable (no experience with it); the typical is set to 140. Be aware the re-fire range is set to call for heat once there is a 20 degree drop before heat is activated again. If you go cooler, say one set for 130, it reheats at 110. The lower you set the temp, the faster your supply gets depleted as you use less cold water in the mix!
I don't have the adjustable, but have heard those sensors may have a shorter life span from those to whom I've spoken: totally unscientific for sure but the forum loves opinions so why not propagate it.
Insight - If you change out the sensor, be sure to put thermal grease between the tank and the sensor head to ensure the most accurate temperature reading. If you changed sensors without doing this, the heat loss between irregular surfaces can cause the tank to hold water much hotter than the 140 setting.
SeeMore is online now   Reply With Quote
Pot metal adjustable reading lamps kincaidjesse Lights - Interior & Exterior 18 04-15-2007 06:28 AM
Are LP regulators adjustable? gparker LP Gas, Piping, Tanks & Regulators 9 01-22-2007 01:51 PM
Stove with adjustable burners tsunami Stoves, Ovens & Microwaves 1 11-25-2006 06:17 PM
Are the storage compartment doors adjustable? Becky B. Exterior Storage Compartments & Access Doors 1 08-24-2006 03:43 PM
is there an adjustable height coffee/dining table wheel interested General Interior Topics 5 10-01-2004 08:46 AM
