Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Water Heaters, Filters & Pumps
Old 09-18-2009, 09:19 PM   #1
mandolindave's Avatar
Profile:
Adding insulation to water heater
My gal bought a used motor home. The PO said the hot water tank had a leak. I think the leak was where I could fit my hand in the side of the tank ! Ya think? Anyway I am replacing the tank, not the whole heater. My friend had a spare.
I will have to remove the insulation, and I was wondering ( while I am at it ) has anyone added more insulation to their water heater. They are often under a bed, like this one. In the winter I might not want any insulation , and in the summer, a whole lot. Is this foolish thinking, crazy compulive behavior, ignorant ramblings, overly idiotic frugalness, typical Airstream overkill, conscientious conservitism, or good ole American ingenuity?
P.S. any hints or warnings concerning the tank replacement would be appreciated Dave
mandolindave is offline   Reply With Quote
Old 09-18-2009, 10:51 PM   #2
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Water heater insulation?
Hi, way too much thought process going on there. Mine has the styrofoam insulation and as far as I'm concerned, it is for keeping the heat in the tank longer; And mine stays hot for quite a long time.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 09-19-2009, 08:10 AM   #3
centennialman's Avatar
Profile:  1966 22' Safari
Centennial , Colorado
My water heater is under the closet in the bathroom. The heater does have the styrofoam cover around and over it. I added an additional two inches of insulation on top of the heater, mostly to minimize sound.
Steve "Centennial Man"
1966 Airstream Safari - Her name is "Aunt Bee"
centennialman is offline   Reply With Quote
Old 09-19-2009, 01:25 PM   #4
Profile:
ok...that's a no and a yes
Can I get a tie breaker?
Old 09-19-2009, 04:50 PM   #5
Kevin245's Avatar
Profile:  1976 31' Sovereign
Rock Hill , South Carolina
No hints here, but addling extra insulation is routinely done in residential applications. I don't know of any reason it would not work in your MoHo. I'd pick up a wrap kit from Lowes, HD, or other. Just make sure the new insulation is securely attached and does not interfere with the plumbing (LPG and Water) and the burner venting.
Best of luck,
Kevin
Experience isn't always the best way to learn...You usually get the lesson first...And the instruction afterwards...
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 08:17 AM
Adding more water tank capacity rpcarlson Plumbing - Systems & Fixtures 8 09-21-2008 01:14 PM
Water heater insulation tlavergne Water Heaters, Filters & Pumps 3 06-30-2007 07:22 PM
HELP-Adding a water heater bypass shinybean Winterizing, Storage, Carports & Covers 6 01-20-2007 08:30 PM
Adding a gray water tank??!! kangol Waste Systems, Tanks & Totes 2 04-21-2004 07:11 PM
