Old 12-07-2002, 03:44 PM   #1
Accessing water pump on a 94 Excella
I'm trying to access my water pump via the false bottom in the CS wardrope. My setup is as follows: While facing in, there is a 90 degree corner-edge trim that runs along the left bottom side. There is another pieces that runs along the back wall and is miter with the other. The false bottom floor runs under both pieces of trim. There are also 4 screws, 1 in the back and 3 up front.
The only way to remove the false floor is to remove the corner-edge trim, but when I was trying to pry/remove the corner-edge pieces, they felt as if they were fasten and I would damage them if I continued. note: there are 2 wardrope doors and there is a vertical piece of wood in the center opening, which the doors close to.
If I need to be more aggressive in removing the trim, please share. I hope someone out there has a simular setup and will be able to walk me through it.
Many Thanks, John
John is offline   Reply With Quote
Old 12-07-2002, 04:51 PM   #2
New Borockton , Alabama
Images: 21
John,
Part of the wardrobe false floor on my 1994 34' Excella is on a hinge and opens right up from the front. Are you sure you don't have a knob in there to pull, or maybe it is missing? The 28' may be different but that would frustrate the heck out of me to have to disassemble the trim, etc just to get to the water pump.
Randy
Old 12-08-2002, 02:44 PM   #3
To make a long story short
Underneath the CS wardrope closet, there is a small storage draw. Remove this draw and now you have access to the water pump and filler hose for the fresh water tank.
John HD,
Again, thanks for taking the time in helping me out!!!
John
Water Pump David Hall Water Heaters, Filters & Pumps 8 01-12-2004 08:31 PM
Water Pump will not turn on AccessMaster Water Heaters, Filters & Pumps 2 12-07-2003 02:08 PM
Water pump question ipso_facto Water Heaters, Filters & Pumps 12 12-04-2003 12:12 PM
Water Pump Joan D'Andrea Water Heaters, Filters & Pumps 3 11-01-2002 06:31 AM
Water Pump Dbraw Water Heaters, Filters & Pumps 6 06-15-2002 10:35 AM
