Old 08-19-2003, 08:33 PM   #1
1983 31' Excella
Bemidji , Minnesota
Send a message via Yahoo to nightowlhooter1
Question 81 excella water heater
I have a 1981 Excella 31 ft. I just ran into trouble with the water heater. It worked fine then the gas ran out. I replaced the gas tanks and the electronic ignitor will not work. I dont know if you have to bleed the line or what. And if you have to bleed the line, is there a easy way to do it besides taking of the main line? When I pushed on the toggle switch to light, no light came on and it did not sound like there was any attempt to spark, nothing happened. Any suggestions are appreciated. Thank you.
nightowlhooter1 is offline   Reply With Quote
Old 08-19-2003, 08:40 PM   #2
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
Just run it ......
Just run it through the cycle of lighting a few times if you are getting the spark from the DSI unit on the water heater.
If it does not light then you may have a problem with the LP valve of the unit not opening.
On mine sometimes it took several minutes of waiting for it to catch after running out of LP.
I just replaced my Atwood 6 gal DSI unit with a new one due to the tank corroding through after 19 years. The new unit was $588.91 installed. $428 for the heater and 2 hours labor....and they saved my old aluminium door for the new unit so I don't have an awful white painted door!
Good luck....it is probably something small....you might also check the connections to make sure they are corrosion free and making good contact.
dscluchfc is offline   Reply With Quote
Old 08-19-2003, 09:10 PM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Or you can light your cooktop to vent some of the air from the lines to speed the process up. Until the unit lights it is going to sound weird.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-19-2003, 10:02 PM   #4
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
Also....
I think you may need to check your wiring connections to make sure they are making contact at the water heater.
When you flip the switch and go outside to the waterheater it should be making the spark trying to light the heater if all the contacts are working.
Also, your DSI unit that makes the spark may have failed and you may need to replace the spark unit.
And, finally, also check your fuse panel to make sure all those little glass fuses are intact. One of the fuses will go to your DSI circuit since you can run the water heater self contained when not hooked up to shore power. When you ran out of propane the fuse may have shorted out with the heater trying to light and having no propane.
Beyond those steps, I would be having to take it in to an RV dealer for service.
Old 08-20-2003, 07:33 AM   #5
If you have had wet weather, run a hair dryer over entire unit including all electrical connections......damp weather makes them act funny.
George Jr.
George Jr. is offline   Reply With Quote
Old 08-20-2003, 07:50 AM   #6
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
'81 Excella MH water htr.
This past weekend, I too had a prob. w/ water heater. I pressed the optional lighter installed on the gauge panel, and I heard the heater light up. But when i went outside to check, the sparker just kept on clicking away and did not stop. I ran it for 5 minutes and still clicked, so I turned it off. Is this heater supposed to click like that or was it a stuck sparker?
Astrodokk is offline   Reply With Quote
Old 08-20-2003, 08:52 AM   #7
Silvertwinky's Avatar
South Shore , Kentucky
Mine will do that sometimes when I first turn it on while I'm waiting on the gas to get to the water heater. When the gas lines are full, I’ve not had that problem!
Visit our church on the web!
"A safe camper is a Happy Camper"
Bill & Donna
Air Forums Member # 2360
Silvertwinky is offline   Reply With Quote
Water Heater Craig 1978- 1979 Excella 500 7 10-01-2007 05:16 PM
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 05:37 PM
Water Heater Advice! John Sims Water Heaters, Filters & Pumps 1 06-16-2003 08:43 PM
Could Water Heater Tank Be Filled with Junk? heyskipper Water Heaters, Filters & Pumps 4 03-17-2003 07:26 AM
